Drying Time - VP540i Print & Cut
Post Sat Feb 09, 2019 9:07 pm
We are using a VP540i Roland.
Having printed and cut our artwork to make wall stickers (continuous operation on the Roland), how long should we be leaving the printed media stud on end to allow the inks to cure before we weed and apply application tape?
Post Sat Feb 09, 2019 9:30 pm
Re: Drying Time - VP540i Print & Cut
Gas out time is 48hrs before laminating. It allows everything to settle, adhesive on the back etc.. needs to be a Warm and dry room. If you don’t have a fan you should flip the roll round once or twice as all the gas will sit at the bottom of the roll.
That said should be touch dry within a few hours if not straight away. Make sure your heater is running to media default and not a low heat. Personally though I would leave them to gas out as getting vinyls to stick to various paints can be a nightmare and sometimes just not possible.
Post Sat Feb 09, 2019 9:45 pm
Thank you for your reply Chris. We have only been allowing 24 hours for the gassing off process. We have been having a few issues with the wall stickers that we have been making curling from the outer edges on some of the stickers that contain darker colours. It maybe that we have not been allowing longer enough for the inks to gas off fully. We will now try 48 hrs and see how we get on. Thanks again.
Post Sat Feb 09, 2019 10:23 pm
Hi Christian,
From my understanding that is exactly what would happen. If the colour is super dark/heavy on print then you could leave it even longer. We tend to leave wrap at least 72hrs, although last car I did I left for over a week before laminating. Better safe than sorry if you can.
Roland DG UK Ltd
Roland DG UK Ltd
Post Mon Feb 11, 2019 12:30 pm
Hiya,
Lots of variables here...
  • What ink you are running
    How heavy the print is (how much ink is going down)
    How long the finished product needs to last
    How you outgas - as previous comments
    What material you are printing on
    If you are using the correct media profile
    What adhesive your material has
    And...what the paint/finish is on the walls you are applying to!
Post Mon Feb 11, 2019 1:03 pm
1) Wash a t-shirt and leave it to dry out on the open in London.
2) Wash a t-shirt and leave it to dry out on the open in Dubai.
One will dry quicker.
As Joe says, lots of variables.
Drying prints in one workshop in 24h, doesn’t mean that this will be the case with another workshop.
You need to test this within your workshop/ equipment/ profiles
Return to Roland Printers
In total there are 88 users online ::
1 registered, 0 hidden and 87 guests
