Wrapping a caravan, vinyl recommendations please?
Post Sun Aug 12, 2018 7:59 pm
Hi, can anyone suggest a cheap vinyl that would be suitable for wrapping a caravan? The surface has a rippled finish so I'm guessing I'd need a wrap material of some type or do you think I'd get away with normal vinyl? There are no corners as such to conform around. Its only a cheap caravan I bought to see how we get on with it so don't want to spend a fortune. I've attached a pic showing the type of finish it has. Thanks as always
Post Sun Aug 12, 2018 9:29 pm
Re: Wrapping a caravan
David I would have thought one of those super high - tack vinyls for wrapping concrete walls would work on this surface. I believe Arlon has one.
Post Mon Aug 13, 2018 8:55 am
Re: Wrapping a caravan, vinyl recommendations please?
I would try Oracal 751 which is a cast vinyl but not as expensive as a true wrapping vinyl. I would be concerned that a cheaper calandered vinyl would not conform enough or stay put in the dimples.
Maybe use some kind of sponge/flexible roller to press the vinyl into the dimples which should act as an air release system providing chanels for the air to escape during application?
Post Mon Aug 13, 2018 9:37 am
Simon Worrall wrote:David I would have thought one of those super high - tack vinyls for wrapping concrete walls would work on this surface. I believe Arlon has one.
Second that. Did a porta cabin just last week that was like this. We use averys printable polymeric though.
Post Tue Aug 14, 2018 12:11 pm
Thanks. Must get a chat with our supplier and get a couple of sample to try. Will be stored in a barn for the next 6 months so plenty of time to do it at my leisure
Post Tue Aug 14, 2018 5:38 pm
Orafol 3951HT
I asked this question last month for a same surface trailer. No 3D surface. Flat side trailer.
Non high tack vinyl will fail on this project.
The manufacturer of the trailer in Germany also recommends this vinyl.
Post Thu Aug 16, 2018 12:16 am
Cheers Pane, will get a bit of that to try as well :-) Sounds like it will be great fun to fit been high tack!
Return to Vehicle Wrapping
cianbyrne, Glenn Sharp
In total there are 107 users online ::
4 registered, 0 hidden and 103 guests
