Drywipe Magnetic Boards - Layer under vinyl to make magnetic
Post Mon Jan 15, 2018 10:15 am
Hi Guys
Wondering if someone can help with this
I need to do a quote for a client for a number of custom drywipe boards with various visual bits printed on them
I'm almost certain I have seen a material as a show that can be applied to the ACM board and then covered with vinyl to make the board magnetic
We were going to use steel backing but this would make some of the larger boards really heavy
Any ideas guys?
Post Mon Jan 15, 2018 10:29 am
Re: Drywipe Magnetic Boards - Layer under vinyl to make magnetic
Morning James,
Perspex distribution do a galvanised steel composite panel, called 'Multishied'
it has a magnetically receptive 0.25 steel skin... says me reading it from the sample on my desk :smiles:
Is this the kind of thing your after?
Post Mon Jan 15, 2018 10:45 am
Hi James. Sign and digital here in Dublin do a material which you can print on and is magnetic.
Post Mon Jan 15, 2018 10:52 am
Martin Cole wrote:Morning James,
As long as it can hold magnetics I guess right thanks Martin....Always worth posting these types of questions, as you have just proved there is a wealth of knowledge here.
Let me know when your down next...We due a catch up mate...Been a while
Post Mon Jan 15, 2018 11:01 am
We've a roll of adhesive ferrous magnetic sheet here. I think it came from Pyramid.
Used exactly how you're needing it, and I'm sure it's printable although we already printed the vinyl to mounted that to it.
Post Mon Jan 15, 2018 11:27 am
Ferrous vinyl doesn't have the magnetic grab of the steel sheet used for blank drywipe boards. Best to buy in a framed blank drywipe board and add the printed vinyl graphic with drywipe laminate over the top and cut it back to the frame. Gives a much nicer end product.
Post Mon Jan 15, 2018 11:29 am
Yes we've bought in standard framed whiteboards from www.adboards.com and covered in digital print in the past. Gives a better finish than just flat panels. :thumbsup:
Post Mon Jan 15, 2018 11:32 am
Bisbell magnetic do a whole range of magnetic products, as well as vehicle grade magnetic I use to use their self adhesive ferro sheeting for custom dry wipe boards, use to do quite a few for Haulage Companies, not used them for a long time now as not really doing much work.
https://www.bisbellmagnets.com/
Post Mon Jan 15, 2018 11:43 am
Hi James,
I think they have just introduced this, definitely magnetic.
https://www.perspex.co.uk/products/alum ... ltishield/
It has been a while, will get down to see you again soon.. :thumbsup:
Post Mon Jan 15, 2018 12:02 pm
Post Mon Jan 15, 2018 10:27 pm
I produced a number of magnetic faced ACM boards a couple of years ago using a ferrous material from Anchor Magnets (www.anchormagnets.com). I found them to be very helpful, they laminated 20 metres of relective vinyl onto some normal magnetic sheet for me at the same time, for a charge of course, awkward job with my steel made laminater.
They have a good catalogue of products which I used many times.
In total there are 39 users online ::
3 registered, 0 hidden and 36 guests
Iain George, Luke Culpin
