PRICING - THAT OLD CHESTNUT
Mike Thornley
Post Thu Jan 04, 2018 11:07 am
Just wondering what you guys would charge for the following, just to see I am in the ballpark on costings.
I realise people like to guard their prices
8ft x 2ft Dibond Hoarding grade, with a full colour graphic (supplied) printed and laminated
Flat panel only
Thank you
Mike Thornley
Post Thu Jan 04, 2018 11:13 am
Re: PRICING - THAT OLD CHESTNUT
As an addition if divulging prices is to sensitive, what do you tend to mark up board materials by? Like dibond, core, foamex etc
Martyn Heath
Post Thu Jan 04, 2018 2:50 pm
i would be around the 180.00 mark. depending on a few variables. If i understood right thats supplied fitted to the dibond.
Yes you should add markup to your substrates. i add 50%
Post Thu Jan 04, 2018 3:37 pm
Not pricing as such, but Something you should consider when quoting. Your offering a short term budget hoarding board with a printed vinyl which is laminated to extend the life. If the customer is looking for a short term budget sign you will save a bit more on material and labour losing the the laminate from the job.
The only time I would include a laminate on a budget sign is if it will be subjected to UV, chemical or abrasion damage. Even then I would price it separate and offer it as an additional option.
Mike Thornley
Post Thu Jan 04, 2018 4:21 pm
Hi Martyn
I am right in thinking you are not in the UK?
Mike Thornley
I've based my quote on £50 per square meter.
David Hammond
Post Thu Jan 04, 2018 4:30 pm
We'd be around the same as Martyn - Depends on the customer and what we think we can get away with :lol:
£50 Sq/M, printed, laminated and on Composite... :yikes:
When I first set up we were charging £45.00 Sq/M for printed laminated vinyl.
Martyn Heath
Post Thu Jan 04, 2018 5:12 pm
Yes your right im not in the uk but the market is the same, material costs and pricing is like for like really.
Lee Reeves
Post Thu Jan 04, 2018 6:50 pm
Our trade price would be around £62 +vat and delivery
Chris Wilson
Post Thu Jan 04, 2018 10:59 pm
We did a pitch of 50 for just a wee bit more than lee each. Supply only. As rob said a lot of variables. More time talking to customer the more chance you have of get a hint towards what they were paying if that’s the case. Or just ask.
Jamie Hunt
Post Fri Jan 05, 2018 9:34 am
I base my digitally printed vinyl onto ACM at £90 per sq mtr so £130-00 if i was applying to Foamex it would be £75-00 per sq mtr so £110-00 this doesn’t include artwork cost which could add an extra £25-50 on top and doesn’t include fitting the sign on site again which could be up-to £50-00 per hr, which I’ve Just worked my overheads out and this is what i should be charging an hour .
Try using this pricing structure to see if your on the right guidelines http://www.estimatesoftware.com/files// ... _right.pdf
To download a little pricing program just put your email in here and it will send you a download link , its very good and gives you a good idea of what you should be charging per hour
http://www.estimatesoftware.com/calculators
Just to add don’t worry about the dollars at the end of the day, there only numbers just put your UK pounds or whatever currency you use it still works the same way,
I had a demo yesterday with Clarity Professional which I thought was to complicated and the Lite version wasn’t enough for what I needed so im sticking with Estimate i just need to tweak it a bit to help me out more on pricing
Hugh Potter
Post Fri Jan 05, 2018 4:20 pm
For a 5 or 7 yr laminated print on acm I charge £280 for a regular, £320 for a one off, for a 2440x610 £1550 & £175 respectively. A little less for 3yr print or dirt cheap acm.
Martin Cole
Post Fri Jan 05, 2018 6:59 pm
Hugh Potter wrote: for a 2440x610 £1550
Bit steep Hugh....no wonder your loaded :wink:
David Hammond
Post Fri Jan 05, 2018 7:11 pm
I'm loading the van up and moving down south, I'll do it for £1500 :lol: :lol:
Post Sat Jan 06, 2018 11:11 pm
Mike Thornley
Post Mon Jan 08, 2018 4:16 pm
Thanks of the replies - appreciated
The hoarding is for the pitch side of a local rugby club, feedback today is that some other company has priced at £50 all in.
No point in being a busy fool.
David Hammond
Post Mon Jan 08, 2018 4:21 pm
Correct, and from experience, the artwork will either be a word document, or a postage stamp sized JPEG :lol:
Mike Thornley
Post Mon Jan 08, 2018 4:25 pm
Hi David
For once in this instance is a PDF at the correct size.
Post Mon Jan 08, 2018 4:26 pm
Colin Crabb
Post Mon Jan 08, 2018 4:48 pm
£50 for an 8x4 panel...... :shake:
Mike Thornley
Post Mon Jan 08, 2018 6:16 pm
Its 8 x 2, but still have to buy the 8 x 4
Derek Heron
Post Mon Jan 08, 2018 8:41 pm
i quoted on similar diabond pitch side panels
went to the ground and measured up etc noticed the old ones were foamex and told them the different in price
oh no we want diabond blah blah
didn't get the job :rollseyes:
popped by months later
you guessed it 3mm foamex pinned to ply .cracked and split
i even got asked to quote again the following year
derek
Pane Talev
Post Mon Jan 08, 2018 9:07 pm
£50 for 8x2 as one off is not healthy and will get you depressed sooner or later.
Hugh Potter
Post Mon Jan 08, 2018 9:10 pm
oops!! I wish I could get that!!
I do my old rugby club, I was involved with the advertising from the beginning so specified 3050 x 750 composite from the off, nice and uniform, easy to clean and they last _ I made and donated the scoreboard which, along with some of the original signs is still going well nearly 8years on! I charge £180 for those with a 3yr laminated print, or £90 for a re-cover of an old one.
anyone charging £50 for a sign that size is either deluded or robbing their boss blind when doing their private job on the weekend! . £50 would just cover the composite and delivery on a single sheet order!
1 registered, 0 hidden and 49 guests
