How to produce car stickers for local sports club?
Post Wed Dec 21, 2016 4:32 pm
Any useful materials and printing tips for creating car stickers.
Is cling vinyl only option?
Post Wed Dec 21, 2016 4:51 pm
Re: How to produce car stickers for local sports club?
If you want them for inside glass?......reverse print on clear them laminate with white.
Post Wed Dec 21, 2016 5:36 pm
Same as above really if they are for inside the window, to be viewed from the outside.
Also little trick I recently learnt to contour cut for that use... before flooding/laminating it with white vinyl, put masking tape over all the reg marks the cutter uses, lay the white down over the top, then remove the masking tape to show the reg marks again.
The cutter can now see the reg marks and cut the shape out through both the white vinyl and the clear vinyl! Obviously you'll need to adjust the cutting depth to accommodate but works a treat!
Post Wed Dec 21, 2016 6:31 pm
As above, although we've done both methods. Trouble is you end up with a roll of cling that rarely gets used.
If you're flooding with white, it's handy to watch your plotter read the reg marks, as our Graphtec starts reading quite far away from the mark, and it does occasionally pick up the difference between the white vinyl, and clear vinyl as the mark, and it really buggers the cuts up.
Post Wed Dec 21, 2016 7:47 pm
I have reverse printed on clear before then sprayed white cellulose from a spray can takes a bit of practice to get an even coat
Post Thu Dec 22, 2016 11:03 pm
I must be missing something as i tought the easiset way would be to use white static cling its perfect as it can be contour cut im doing some freebies now for a local fire station i think the stuff is great to use and sticks really well onto car windows on the inside
Post Fri Dec 23, 2016 3:32 pm
Peter Wynne wrote:Also little trick I recently learnt to contour cut for that use... before flooding/laminating it with white vinyl, put masking tape over all the reg marks the cutter uses, lay the white down over the top, then remove the masking tape to show the reg marks again.
I miss something. How do you remove the masking tape after laminating?
Post Fri Dec 23, 2016 3:36 pm
I normally just very gently score through the white vinyl over the masking tape (very roughly) then peel away the masking tape leaving the printed vinyl underneath.
Post Fri Dec 23, 2016 3:41 pm
ok thanks :thumbsup:
Brian Turner
Brian Turner
