Advice needed on making a Flange sign please?
Jonathan feeney
Post Wed Nov 23, 2016 7:41 pm
Hello ,
Jist a quick one has anyone ever made a flange sign from ACM or similar material ?i was thinking about routering a fold on one side so it can be fixed to the wall ?
Post Thu Nov 24, 2016 9:43 am
Re: Flange sign- here's one I made earlier
Here's one I made earlier
Jonathan feeney
Post Thu Nov 24, 2016 1:18 pm
Re: Flange sign
Cheers phil is it just folded acm ?
Post Thu Nov 24, 2016 1:49 pm
Re: Flange sign - here's one I made earlier
Folded ACM with PVC (Forrex) top and bottom caps.
A simple routed and folded panel won't be strong enough. Here's a diagram showing how it was folded looking down through the sign
James Sahota
Post Fri Nov 25, 2016 8:52 pm
Re: Flange sign
I like this a lot!
Simon Worrall
Post Sat Nov 26, 2016 3:18 am
Re: Advice needed on making a Flange sign please?
Nice design, Phill!
:claps:
Post Sat Nov 26, 2016 2:33 pm
I made one very similar to Phills for a customer but then never put it up as I was worried that the effects of the wind might quickly cause it to fail along the joins. Ended up just using a standard projecting sign instead. Thought about using ally angle bonded or riveted at the joins to give it a bit more strength but never got round to trying it. Countersunk rivets would probably be ok & still keep the faces completely flat but then you have to think about covering it to hide the heads :blushing:
The outer aluminium skin is very thin & a projecting sign will move a bit no matter how light the winds are.
I just wasn't confident enough to risk putting it outside. Phill has his one in the unit & I am sure as an internal sign they would be completely fine :lol: :lol:
Still kicking about the unit somewhere, will have to find it & take a couple of pictures :lol:
Jonathan feeney
Post Sat Nov 26, 2016 2:44 pm
The one im lookong to install in indoors in a shopping centre so no wind im thinking of going down tbe road of 2mm alu and bendi g a flange into it
Post Sat Nov 26, 2016 2:58 pm
How do you intend to bend it? 2mm ally isn't as easy to bend in a straight line as you might think or you you have a bending machine ?
You will also probably get a tighter radius curve using 3mm composite that has been v-grooved as opposed to 2mm solid ally sheet plus the composite will be cheaper. I used to do quite a lot of work with 2mm ally years ago but had the tools to be able to do that :lol: :lol:
3 registered, 0 hidden and 55 guests
