Router bit help needed please
Rich Cooper
Post Fri Apr 15, 2016 8:24 pm
Hi everyone,
Im hoping someone on here can point me in the right direction for a 90 degree router bit with a 3mm flat bottom for routing tray signs, ive searched the usual online places but cant seam to find one anywhere.
Any help is appretiated thanks Rich
Kevin Flowers
Post Fri Apr 15, 2016 8:39 pm
Re: Router bit help needed please
ITC http://www.itc-ltd.co.uk/products/ sell them page 45 in the Folio catalogue Listed as Dibond tool
https://issuu.com/itcltd/docs/folio_cat ... 6_web_lr/1
Duncan Wilkie
Post Sat Apr 16, 2016 3:10 am
Gerber makes a bit specifically for that.
Simon Worrall
Post Sat Apr 16, 2016 5:07 am
I took a normal 90 degree bit and ground off the bottom couple of mm on a grinder. Needs must, couldnt find the proper one in NZ! Works a treat.
You have to use the "spiral down" approach when cutting so it doesn't overheat when starting the cut..
Simon.
James Sahota
Post Sat Apr 16, 2016 6:38 am
Complete CNC Solution will be able to assist you with this
It's not just the tool your buying remember you need to know the correct settings to run this at...guys at CCS can advice on all settings needed according to the machine your running.
Will save you a lot of messing around!
Rich Cooper
Post Sun Apr 17, 2016 12:40 pm
Brilliant thanks everyone for the help, ill get one ordered this afternoon.
David Mitchell
Post Mon Apr 18, 2016 8:15 am
http://www.trenddirectuk.com/alu-01x1-4tc.html
i bought one from here last month, and my first ever sign tray i made is proudly on the local main street :)
Duncan Wilkie
Post Mon Apr 18, 2016 3:53 pm
It seems the tips of V carving bits have a tendency to break of, so we just use one in that condition to slot the ACP. It works well for us. Nice tight bends.
Just a heads up there are different grades of these ACP sheets. The Econo grade has a thinner metal face and it is suitable only for flat applications I will usually crack when bent. Use the panels with the thicker "skin". Ex. E-Panel is thin, Dibond is thicker - same manufacturer.
Chris Wilson
Chris Wilson
