Coloured film to fit over floodlights
Post Tue Oct 27, 2015 4:36 pm
Last year i created this effect using normal coloured vinyl onto the floodlight glass. They want the same this year and i'm trying to find a more suitable film. The problem last time was the vinyl started to melt with the heat of the bulb. I know i can get gel sheets but these aren't self adhesive are they? Ive tried looking for coloured bulbs but cant find any. The lights are standard floodlights with RX7s halogen bulbs.
Any suggestions?
Post Wed Oct 28, 2015 12:03 am
Re: Coloured film to fit over floodlights
What about coloured glass on the inside.
Post Wed Oct 28, 2015 3:18 am
If you can get something suitable that isn't self adhesive you may be able to make it self adhesive using a print mounting film, I do this with quite a lot of materials that I need to stick to something.
How many do you have to do Ewan? How much mount film would you need for the job??
Post Wed Oct 28, 2015 9:16 am
Only 2 to do, approx 200X200 each. I think I may have found red LED replacement bulbs . Need to check the size today
Post Wed Oct 28, 2015 9:23 am
You should be able to get LED Lamps with just about any fitting these days but they may not be as bright. If you do end up needing a bit of D/S mounting film I have optically clear film & can put a bit in the post for you Ewan.
Post Wed Oct 28, 2015 9:48 am
Ewan
Hexis have a good range of coloured films, not sure how it would be with the heat though, they will send you 2 or 3 samples free of charge.
Oracal also do the 8300 coloured range, commonly used for tinting car lights
Bob
Post Wed Oct 28, 2015 1:36 pm
Forget the name of the film we used in the theater but if you contact either your local Theater and ask the Lighting crew or try somewhere like Tandy as they sell disco lights.
Its not a sticky film.......... wait................................
https://www.stagedepot.co.uk/lighting/l ... wwod_fMCgQ
There you go lol
Post Wed Oct 28, 2015 4:33 pm
Thanks for the suggestions everyone. Vic that link was spot on. The film is suitable up to 220 degrees which is higher than any of "our" vinyls.
Martin, thanks for the offer but i can attach this with high temp resistant tape.
Will try and remember to post a photo when its done
Post Wed Nov 04, 2015 10:47 am
Update!
Ordered the coloured film from stage depot and fitted over the glass using heat resistant tape. The film is rated up to 220 degrees. I put my laser thermometer on the lights and the hottest they got was 113 degrees so all good. Here's the result. If i would change anything it would be stronger bulbs, These ones are 150w but i reckon 200 would give a better glow.
Gil Johnson, Robert Lambie
