Hot or cold lamination - advice needed please?
Ewan Evans
Post Sun Sep 21, 2014 2:08 am
Hi everyone,
I've been using a cold laminator for the last couple of years which sometimes gives me a bit of grief applying Oraguard 290 cast laminate. I'm hopefully going to be purchasing a 54 inch printer/cutter in the next couple of weeks and was wondering if the Chinese laminators which are basically just two powered rollers are suitable for applying Oraguard 215 and 290 laminates without heat?
While speaking to a few people regarding laminating I have been given contradicting advice. Are cold laminators suitable for most vinyl/laminate combos?
The one that I have been using is again basically just two powered 800mm rollers manufactured by Hot Press. This laminator is great for applying Oraguard 200 laminate but I want to use polymeric and cast vinyls and I'm not sure if it's my technique that's not up to scratch or the machinery.
Any help on this issue would be great.
Ewan
David Hammond
Post Sun Sep 21, 2014 7:17 am
We have an easymount 1600 cold laminator.
It will laminate, cast, mono, and polymeric film easily.
We did have a polar signs prior to this that, well... wouldn't laminate anything. The easymount has a far superior tensioning system, we've done runs of 25+m withoit a snag.
What issues are you experiencing?
Tom Haley
Post Sun Sep 21, 2014 9:02 am
Same as David, where I was last we had a 1600 easymount hot/cold but only ever used it cold. We didn't really do any wrapping but laminated plenty of wrap vinyl for others.
We also had no problems doing long runs, up to 50m.
Post Sun Sep 21, 2014 12:03 pm
we run a 65 inch wide cold laminator and have for about 10 years. :D
Ewan Evans
Post Mon Sep 22, 2014 10:18 pm
Thanks for the replies. I ordered Oraguard 215 poly laminate today to try with our existing laminator. Am I right in saying that hot only reduces silvering slightly?
Ewan
Cheryl Smith
Post Tue Sep 23, 2014 8:31 am
I run a seal hot/cold...I use it on hot, no silvering...but you do need to pay careful attention to the tensioning as you can stretch the laminate, leading to pull back on install...every days a school day :roll:
Vic Adair
Post Wed Sep 24, 2014 4:24 pm
We have a seal hot/cold too and I 95% of the time just use cold laminating but when we need the best result I tend to cold laminate first then run it through after with the heat on. This may seem like double handling but you dont get the stretching like cheryl says and it comes out just the same.
Cheryl Smith
Post Wed Sep 24, 2014 4:56 pm
good idea Vic
Stafford Cox
Post Fri Sep 26, 2014 1:26 pm
Vic Adair wrote:We have a seal hot/cold too and I 95% of the time just use cold laminating but when we need the best result I tend to cold laminate first then run it through after with the heat on. This may seem like double handling but you dont get the stretching like cheryl says and it comes out just the same.
That is a great little hint Vic. Thanks for sharing.
There is also heat assisted laminating. Like Robs laminator, the Neolt 1650C / Uniform Guardsman he has is classed as a heat assisted as one of the rollers will run at 50 degrees, rather than 120 degrees on a hot laminator.
Stafford
4 registered, 0 hidden and 64 guests
Alex Crosbie, Luke Culpin
