corel bleed
Post Tue Mar 18, 2014 4:39 pm
corel bleed
used to doing business cards but this has me going mad.
added 3mm bleed all round as usual with crops but sizing exact size as card and shows no bleed.
Must be missing a check button somewhere and cannot remember how to resolve, any ideas?
Post Tue Mar 18, 2014 5:09 pm
Are you meaning the prepress settings in publish to pdf?
Gary
Post Tue Mar 18, 2014 5:16 pm
yes, re-booted and still the same.
There is an image with fade across the card. Just converted to bitmap and better
Post Tue Mar 18, 2014 5:18 pm
Update, problem solved. Fade needed to be converted to bmp
Having one of those days!
Thanks for the help Gary
Post Wed Mar 19, 2014 10:47 am
I usually publish to pdf using pdfx1a option and this normally sorts any transperancy and lens issues when doing litho artwork, always flatten completely for digital though or if importing into another programme (including Draw)
Bleed - if publishing to pdf
settings - Pre press tab - tick bleed and set required amount
If printing to cutepdf (or similar)
Print - layout - tick bleed limit and set required amount
Export to EPS - advanced tab - Bounding box PAGE - tick bleed limit and set required amount.
I have found that many trade printers prefer pdfx1a but eps seems better for many digital rips that said alot of trade printers put your files into their programme of choice for batching purposes and this is where the problems seem to start so the flatter the file - the more reliable it is for everybody
Alan d
Post Wed Mar 19, 2014 10:53 am
Thanks Alan.
Cute PDF got me out of trouble when Corel playing up for exports
Top info as usual
Return to Corel Software
Mike Wilkinson
3 registered, 0 hidden and 102 guests
Mike Wilkinson
