Signlab, Flexisign or Omega Composer?
Robert Rowlandson
Post Tue Oct 29, 2013 11:41 am
Hi everyone,
I'm interested to find out how Flexisign and Signlab compares to Omega Composer? What are you thoughts and experiences with these software packages?
Rob
Post Tue Oct 29, 2013 12:09 pm
I started out on Gerber software 24 years ago... i then looked into flexi, but opted for Signlab instead. ive never looked back... purchased a further 4 signlab packages since.
all software has come on so far from back then... i still use signlab to this day, i use photoshop and dedicated RIP for printing side of things.
Post Tue Oct 29, 2013 12:53 pm
did you get omega with the cutter?
Robert Rowlandson
Post Tue Oct 29, 2013 1:50 pm
Chris Windebank wrote:did you get omega with the cutter?
Hi Chris,
No unfortunately not so I need to make a choice which way to go with the software. I downloaded the Signlab trial version and it didn't look as easy to use as my friends Omega software, but everyone seems to rate Signlab and I don't see much mentioned about Composer! I'm new to this so whatever software I choose I'm going to be learning from scratch.. the only bonus from choosing composer is that my friend already uses it on a daily basis and can help me out.
I've tried to find used copies of software packages but they are rare as rocking horse droppings! What software do you use?
Reza Faezi
Post Tue Oct 29, 2013 2:32 pm
+1 for Signlab :)
Post Tue Oct 29, 2013 2:53 pm
Have you tried the trial version of Flexi as well? There is also other software that people use, vinylmaster also has a trial download & a lot of people seem to use corel & illustrator as well.
Post Tue Oct 29, 2013 3:55 pm
I use composer too and love it. Not far from you and run the same machine. Ask on here for software, I have an old copy but want to keep as a back up.
Robert Rowlandson
Post Tue Oct 29, 2013 4:06 pm
Martin,
I've not tried the Flexi download but i'll have a look at it. Will Coral and Illustrator output direct to a cutter?
Chris,
Do you have the details of a Gerber engineer? My cutter cuts straight lines very well but in circles like the letter O and the number 8 for example the lines seem bumpy? it's not shocking but is noticeable if you look properly. Have you come across this before?
I'm sure I asked in the software section if any one had any old copies of software they'd like to sell but I think it got deleted?
Post Tue Oct 29, 2013 4:14 pm
there are plug ins I believe that allow you to cut direct from Corel and Illy. Never used them so not sure.
Am sure Stafford will read this later and can advise on engineer.
Ewan Chrystal
Post Tue Oct 29, 2013 5:14 pm
Ive been using flexisign since i started in January. I can't comment on the others but flexi does everything i ask it to do and probably much more that i haven't figured out yet
Duncan Wilkie
Post Wed Oct 30, 2013 12:58 am
Gerber Omega here. I've been a Gerber guy from the start. A really stable workhorse.
Post Wed Oct 30, 2013 12:04 pm
Same as Chris, I believe there are plug ins but never used them so can't comment. Try doing a search on the forum as has been talked about in the past.
I use vinylmaster or VMX as it is known now. Free download available if you want to try it but it really will be down to personal choice.
Karen McGinty
Post Wed Oct 30, 2013 10:32 pm
Haven't tried the others so don't know how they compare, but I have found no cult with FlexiSign Pro. We have used it since we started and have not found anything we needed to do that it can't do! We run 8.1
K x
Post Wed Oct 30, 2013 11:51 pm
If you do opt for flexisign Robert then buy the version you need to get you started, if your just running a plotter then 3 grand is a lot of money to spend on software that will do more than you need. Same goes for signlab I beleive, comes in modules so you can start of small & build up.
Karen McGinty
Post Wed Oct 30, 2013 11:54 pm
Karen McGinty wrote:Haven't tried the others so don't know how they compare, but I have found no cult with FlexiSign Pro. We have used it since we started and have not found anything we needed to do that it can't do! We run 8.1
K x
"Cult" should read fault!! Must proof read before submitting in future!! K :lol1:
Robert Rowlandson
Post Thu Oct 31, 2013 2:15 pm
Thanks everyone.
Its seems a pretty even split to me. I'll take a look at all of them. If they offer some training to go with the software that'll be a big bonus!
Rob
Kev Mayger
Post Thu Oct 31, 2013 4:00 pm
Illustrator!
Gavin Dooley
Post Thu Oct 31, 2013 4:39 pm
Robert, Signlab all the way for me. Problem with your curve cutting is probably
the blade holder. I use Roland machines & when I had the same issue that's
what it was.
Robert Rowlandson
Post Thu Oct 31, 2013 5:33 pm
Gavin Dooley wrote:Robert, Signlab all the way for me. Problem with your curve cutting is probably
what it was.
Was it an easy (cheap) fix Gavin?
Jon Marshall
Post Thu Oct 31, 2013 5:35 pm
Flexisign is the best package out there but if I was starting again today I would learn Illustrator
Gavin Dooley
Post Thu Oct 31, 2013 5:47 pm
Rob, It was about 10 years ago, I think about 60 euro, simple change over on
the Roland, I don't know about your machine. Should be cheaper in UK, I'm in
Ireland so everything is more expensive.
George Zerbino
Post Thu Oct 31, 2013 8:53 pm
+1 for Omega for me, power user for 23 years :D
Chris Windebank
Post Fri Nov 01, 2013 10:36 am
if you need a hand with the machine just shout. Often through Harlow
Robert Rowlandson
Post Fri Nov 01, 2013 10:40 am
Chris Windebank wrote:if you need a hand with the machine just shout. Often through Harlow
I very well might do mate! Trying to get the signlab demo to output to the cutter and it's not going according to plan. I've just manually selected the port in Signlab and we'll see what happens now! Where are you based?
Chris Windebank
Post Fri Nov 01, 2013 10:47 am
sunny stevenage
Alan Drury
Post Fri Nov 01, 2013 2:33 pm
Crikey, I'm only down the road from Harlow myself - I'm in Little Chesterford near Saffron Walden. I run both Signlab and Corel Draw and cut to Summa and Graphtec machines from both packages.
Alan d
Chris Windebank
Post Fri Nov 01, 2013 2:41 pm
will have to pop in for a cuppa too then.
Out of interest what package do you use to run from corel?
Robert Rowlandson
Post Fri Nov 01, 2013 3:11 pm
Good to know there's some experienced sign guys nearby. I can see this industry has a huge learning curve! On a side note I've now got signlab outputting to the cutter! :D
Alan Drury
Post Fri Nov 01, 2013 3:22 pm
Chris, I use Cutting Master which I think is a cut down Flexi cutting front end. It does have some good features but it does seem a little slow so I normally cut and paste from Corel into Signlab which is both fast and more flexible than Cutting Master.
