Air release etched glass film
Post Wed Dec 05, 2012 2:32 pm
I use Grafityp's Air release glass etch film for a an ongoing contract I have with a door manufacturer, however I've just rang to re-order and they have no stock until January, which has left me with a problem.
Does anybody know where I can find something the same or very similar as I have a couple of jobs I need to get done before Christmas, its was Grafityp's TR111 (Glass Silver) that I need to match
Post Wed Dec 05, 2012 2:55 pm
Metamark are now doing their etch range in air release liners.
Post Wed Dec 05, 2012 3:35 pm
Metamark
Thanks Stuart much appreciated, I will give metamark a call
Post Wed Dec 05, 2012 4:56 pm
also spandex do these, try metamark first as they keep stock whereas spandex order in. Same face film whichever you use
Post Wed Dec 05, 2012 5:33 pm
I've just been using the Hexis version and was very impressed. Not particularly cheap compared to conventional film but far easier and quicker to use.
Post Wed Dec 05, 2012 5:38 pm
all around 4.00 - 5.00 per metre for 1220
Post Thu Dec 06, 2012 1:18 pm
should you use air release etch on glass when the side with glue on is showing outside?
i ask this as when i last ordered some from hexis, it was suggested i go for the normal as the glue side faced the street
Post Thu Dec 06, 2012 1:35 pm
i havent heard anyone mention that denise but might be some credibility to what what they say. but ide imagine it depends on how the air release system is achieved. i say that because some are pretty obvious grid like patterns on the rear whilst others are not so. worth considering i think...
i think most reputable suppliers of film now offer an air release etc. first one i ever saw was years ago now and i think it was 3M. Mark Brown of wm smiths came into see me with some back then and it was very simple to apply. he applied an A4 with his finger quick and zero bubbles. :D
Grafityp, Wm Smiths, RHG, Hexis, metamark etc will all do it.
Post Thu Dec 06, 2012 1:36 pm
had no issues using the film this way on glass. At first you can see the small lines but they do disappear.
Post Thu Dec 06, 2012 2:41 pm
thats good to know
Post Thu Dec 06, 2012 4:42 pm
Has anyone of you people had a look at an air release etch with sun shining on it...
I do and It looks awfull, you can see the pattern in wich the glue is laid out on the surface...
I will take a picture next week and post this on this forum.
(Vinyl is applied on inside, needs to been seen for people walking outside)
Post Thu Dec 06, 2012 5:12 pm
Have to say first time I tried it when it came out over a year ago it was shocking. Used app tape and applied inside windows and was as Tim says all streaky. Ripped off and replaced with normal and all ok.
The one from Metamark seems to be ok and is ideal for indoor use especially glass partitions etc.
Grab a 1m sample and try for yourselves
Done this 3m graphic dry and alone last week and looks fab in the daylight
Post Thu Dec 06, 2012 5:14 pm
I've only done small areas with the air release.
I tend to do quite large windows with the standard etch and always apply it wet, like window film, as it seems to get a more even finish without the white pressure marks.
It would appear to defeat the object to use air release and then do it wet, and it crossed my mind that water would also stay in the grooves. So it is interesting to note that even dry these air release grooves may still be visible.
I'd be interested to see the photos Tim.
Post Thu Dec 06, 2012 6:27 pm
I used the Hexis air release on the inside and it looked absolutely fine from the outside.
Post Thu Dec 06, 2012 7:44 pm
Chris Windebank wrote:Have to say first time I tried it when it came out over a year ago it was shocking. Used app tape and applied inside windows and was as Tim says all streaky. Ripped off and replaced with normal and all ok.
I guess you used App tape on the cut graphic Chris. What about the plain panels? Did you use app tape on them?
Post Thu Dec 06, 2012 10:01 pm
Stuart, you are correct mate, i wouldnt advise wet applying air channel adhesive type films, for the same reasons you mention.
these two videos are "Dry Applied" glass etch panels.
"none" of them have air channel adhesive system.
both have graphics cut from the middle of them and have application tape.
one is about a metre square the other about 65 inches by 20 inches.
both fitted in relatively warm offices.
as you can see, "including" the cleaning and preperation of both AND stripping the application tape when done. one takes 4 minutes and the other 6 minutes.
https://www.uksignboards.com/viewtopic.php?t=25690
pay close attention to how im handling the vinyl. its simply a technique of allowing gravity to assist in the application. dont let the vinyl to intimidate you.
Post Fri Dec 07, 2012 8:53 am
Hi Stuart, cut vinyl had app tape but large strip was straight from roll. Used a Teflon squeegee which glides better. Must say I got to the end and put a kink in the etch, went to van and got heat gun out and disappeared without a trace too
Post Tue Dec 11, 2012 12:54 pm
as promised here are some pictures i have taken from the easy apply etch...
(pictures taken by iphone so nevermind colours)
EDIT : etch was not applied by myself! (I would not leave it like that or get paid for that that's for sure)
Post Tue Dec 11, 2012 1:20 pm
Have to say that is bad, no wonder you are not impressed. Had a similar problem with a certain make but the metamark one was ok.
Worth getting a sample to try
What make was this?
Post Tue Dec 11, 2012 2:39 pm
ive used graphityp without issue I think thats air release now - applied dry
john
Post Tue Dec 11, 2012 2:53 pm
The Hexis stuff I used was nothing like that. You could not tell the difference between air release and conventional material once applied, it did have a high initial grab though. I was putting on some pieces 1800mm X 570mm without a hint of a bubble I'm not sure I could say the same with ordinary material especially as there was limited space behind the window which made application awkward.
Post Wed Dec 12, 2012 2:06 pm
That does look a bad finish. But not the air release grid pattern I would have expected. Looks like a load of dust.
Would be interesting to know their installation procedures.
Also what etch is it?
Post Wed Dec 12, 2012 2:28 pm
more close up (larger file)
Ps : it's no dust of whatever, vinyl has regular air release? pattern over the whole surface!
Post Wed Dec 12, 2012 6:21 pm
I know its not dust just saying the effect looks like it.
What brand ? so we know what to avoid.
Post Thu Dec 13, 2012 9:30 am
Yes do say what brand. Hexis stuff is good but I thought a bit expensive. I've just had some material in from Victory (sample) which has the distinctive air release adhesive pattern and that also seems fine once applied to a window and is cheaper but has to be ordered in.
Post Thu Dec 13, 2012 1:17 pm
Tim said it wasn't one of his jobs so he probably doesn't know what brand of vinyl it is.
Martin Cole, Matt Oxley
4 registered, 0 hidden and 55 guests
