Advice needed on Roland Camm 1Pro Cutter please?
Post Tue Oct 23, 2012 7:56 pm
good evening all, my names is Jarrard and I run St Ives Signs in Cornwall, . I have a Roland Camm 1Pro cutter that is over 10 years old and today we got some material stuck in it, we removed the material with now evidence of anything stuck, I have no material width recognition, I get a message " change pinch roller position". I have cleaned and checked all fittings, wires etc,,,
Would look forward to some advise
Jarrard
:D
Last edited by Jarrard Harrison on Tue Oct 23, 2012 8:59 pm, edited 1 time in total.
Post Tue Oct 23, 2012 8:44 pm
Hi Jarrard, bit of an abrupt opening post!!!!
I think if you took the time to introduce yourself in the Welcome Forum and tell us a little about yourself you may get the help you command :wink:
Post Tue Oct 23, 2012 8:52 pm
Cheers Neil for the advice,,, new to this !!! I'll change my post !
Post Tue Oct 23, 2012 9:02 pm
Well done Jarrard, I'm sure you'll get a better response if you take the time to say hi :D
TRADE SUPPLIER
Post Tue Oct 23, 2012 9:25 pm
you do know you can slide the pinch rollers to the left and right for differant widths of vinyl and that they can only be in certain positions.
1/4 inch too much in either direction and you get that error.
are the pinch rollers on a smooth part of the grit roller or on a gritty part?
Post Wed Oct 24, 2012 7:00 am
Morning & thanks for the reply.
I have had this machine from new, 1st problem in over 10 years.
it's not the position of the pinch rollers as they are correct to view, is there anything else on the cutter that senses the width,?? Thanks Jarrard
Post Wed Oct 24, 2012 9:00 am
Behind the pinch rollers you have small blocks sat in a recess.
Not sure what they are possibly magnets.
On a 3 roller machine only the outside ones have these.
Are they all there or maybe been knocked out?
or possible damage to the pinch roller sense board on the cutting head or any wires disconnected from the cutting head.
Post Wed Oct 24, 2012 9:22 am
Hi Tim
Thanks for your help..
Mine is a two pinch roller, I think it must be the small circuit board at the back of the cutting head, take it its the sensor,,, there are no wires loose.
Thanks for your help, is this a Roland part or are there aftermarket suppliers for small parts like this ??
Jarrard
Post Wed Oct 24, 2012 9:34 am
Roland part only I would say.
Probably worth a call to Roland to see if you can test it before ordering anything.
Post Wed Oct 24, 2012 9:38 am
Thanks Tim
Post Wed Oct 24, 2012 9:53 am
Yep Roland Part £12.50 + vat & Delivery
Return to Roland Cutters
In total there are 121 users online ::
2 registered, 0 hidden and 119 guests
