converting from 4 colour to 6 colour mimaki cjv30-130
Post Wed Feb 15, 2012 7:14 pm
I have recently purchased a 6 month old mimaki cjv30-130 running 4 colours - I also have a mimaki cjv30-60 running on 6 colour CMYK lm lc. I want to convert the 130 to 6 colour but am having problems with the conversion process - I have flushed the system and gone through the cleaning/flushing process - switched the machine off and on and am at the stage where i am asked what inkset i am using which is ss21 but then it should give me the option of 4 or 6 colours but is only giving the option of 4 colours. have I missed a process? why havent I got the option of 6 colours? any help would be appreciated - thanks
:police: Mod-Edit
* Please Introduce yourself to our community properly by using the "Say Hello" forum.
Please note: It is FACT, that those using their full proper name accompanied by a Profile Picture and have
introduced themselves to our community get far more replies and help with posts that they make than those without.
It also helps keep UKSB the friendliest sign forum we know of!
Please also take a moment to look over our
Board Rules.
Post Wed Feb 15, 2012 8:39 pm
sorry mod - have now introduced myself and hopefully will be able to offer some help back to other members - cheers Ben
Post Thu Feb 16, 2012 10:09 am
I don't know about the reason why you can't select 6 color option in the menu but switching from/to 4 to 6 colors requires a small modification of the pipe lines behind the cartridges block.
You have to remove 4 bridges that connect 2 carts of the same type. My tech did it when I received the CJV which was preset to 4 colors but I wanted 6 colors+white setting.
This is just for your information in case you did not know that ;-)
Post Thu Feb 16, 2012 10:38 am
thanks for response Fabrice - I have removed the pipe joins and all that side is set to 6 colour but am not getting the option choice of 4 or 6 colour on the LCD? just gives ink choice and 4 colour only? it should give me 4 or 6 option - is it software issue? thanks
Post Thu Feb 16, 2012 10:50 am
maybe something that must be set in service mode to enable the 6 color set? (?)
I don't know more. It's worth get in touch with you CJV30-60 tech by phone if he has any idea.
Post Thu Feb 16, 2012 11:01 am
You will need to start up in service mode and then select the "head wash" option from the #Adjust menu. This will then give you the option to change the ink set.
Post Thu Feb 16, 2012 11:12 am
as you have both 4 et 6 colors CJV30 machines, did you manage to compare the output quality of both configurations?
My tech says that the results are so close that it is no worth using 6 colors setup compared to 4 clors unless I use white (which is only available in 6 colors setup).
As I intend to switch to 4 colors instead of 6 colors, I wonder if I will loose in print quality (especially in the light gray spectrum).
Post Thu Feb 16, 2012 11:18 am
hi fabrice - I have tested same prints on both printers and there is a fair difference in colour between the 2 - this may be minimised with colour settings though
main reason is to keep output consistent if we run the same job on either machine - we do a lot of skintone stickers for pos trays which are colour accurate and need to maintain consistency so would rather run same inkset
thanks
Country: United States (us)
Post Sun Oct 22, 2017 4:22 pm
Re: converting from 4 colour to 6 colour mimaki cjv30-130
I do have the Service Manual in .pdf for the CJV30 if you need it I can send it to you.
Post Sun Oct 22, 2017 4:44 pm
David King wrote:I do have the Service Manual in .pdf for the CJV30 if you need it I can send it to you.
That post is from nearly 6 years ago David, I would like to think that the OP sorted this out a long time ago :lol: :lol: :lol:
Post Sun Oct 22, 2017 4:59 pm
yikes, you are right.
Return to Mimaki Printers
5 registered, 0 hidden and 56 guests
Gil Johnson, Glenn Sharp, Robert Lambie
