Can't find IP Address
Post Fri Nov 12, 2010 1:07 pm
Hi guys,
So i have moved premises this week, got all my equipment across and set up, and get an urgent order to finish by Monday. My grenadier printer is ready to go but when i try and print the PC tells me that it can't find an IP address? I dont have an internet connection until my cabling is completed on Monday and I usually run the printer through a router, so I am attempting to run the LAN cable straight from the PC to the printer. Is this possible as my networking understanding is not great? If it is can anyone suggest the reason for not recognising the IP address.
Any help would be great, thanks.
Post Fri Nov 12, 2010 1:21 pm
sounds like DHCP was in charge by the router assigning your main PC's... reconnect it up how it was and it should be fine.
That means leaving the router on without the internet.
Post Fri Nov 12, 2010 4:43 pm
Still unable to open IP
Cheers Dave,
I have tried connecting through the router as it was previously but still keep getting the same message whenever i try and print.
'failed to open TCP/IP'
TCP/IP: 192.168.1.101:9100. Any other ideas?
Post Fri Nov 12, 2010 5:00 pm
if you google "192.168.1.101:9100" you will find this is a common printer problem discussed on a number of forums. I think your problem is explained in some of the replies given.
Post Fri Nov 12, 2010 5:04 pm
Maybe check IP address?
This is on another post from here.
Turn on printer, press menu, press up arrow 5 times, press 1 right, 3 down, 1 right and 1 right and there is your IP address.
Post Sun Nov 14, 2010 12:57 am
duplicate
Last edited by Johnny Alston on Sun Nov 14, 2010 12:58 am, edited 1 time in total.
Post Sun Nov 14, 2010 12:58 am
go into your original discs and look for the program intercon net tool.
You probably still have it installed on the rip pc to be honest this allows you to access the ip and change the ip on the machine.
Had the same problem couple of weeks back.
Helpful advice on here helped me solve the problem.
Post Sun Nov 14, 2010 1:08 am
at the end of every socket is a light, normally starts flickering when you put it in... i gonna presume its all good.
Post Mon Nov 15, 2010 11:29 am
David,
Is it a possible firewall problem?
Post Mon Nov 15, 2010 1:27 pm
All Sorted!
Thanks for the advice guys. I eventually got to the bottom of the problem. Inter-Con Net Tool resolved the issue.
Return to Uniform Printers
In total there are 86 users online ::
1 registered, 0 hidden and 85 guests
