Scale help in CS3
Post Sun Oct 24, 2010 6:36 pm
Scale help in CS3
Hi all been sent an eps file which I can open in CS3 I need to make some changes to logo size and although I scale the logo with the option as follows
Object , Transform, Scale and tick , scale stokes and effects when I save the logo to resize in siglab etc the stroke wont scale correctly, any ideas thanks Rich
Post Sun Oct 24, 2010 9:11 pm
Rich
is there a reason why you cant open the eps in signlab, and scale there?
Post Sun Oct 24, 2010 9:22 pm
Hi Richard,
Is that illustrator cs3 or photoshop cs3?
If you open in illustrator highlight everything (ctrl & shift & A) grab the top left corner and hold down shift (to keep proportion), drag down to size. Should be it.
Andy
Post Mon Oct 25, 2010 9:23 am
If push comes to shove you can always convert the stroke to an object, no problems then
Post Mon Oct 25, 2010 9:44 am
Thanks Guys, sorted now. Peter for some reason it would not let me import into Signlab. The file was OK in Adobe Illustator but when I saved it out to produce in Signlab every thing but the strokes scaled correctly, worked around it now by saving in Corel first, thanks for looking Rich
Post Mon Oct 25, 2010 10:07 am
Rich
maybe you need to check the lock proportions box before scaling up
Post Mon Oct 25, 2010 10:17 am
Hi Peter this is correct and when I create designs its fine and the effect scales up with the rest, however when I did this with the ESP file created in CS3 it was having none of it, Rich
Post Mon Oct 25, 2010 1:32 pm
Hi Richard,
It is because it is a stroke. It won't scale to proportion, if it was a separate object it would. Stroke never does.
Glad it's sorted.
Andy
TRADE SUPPLIER
Post Mon Oct 25, 2010 2:03 pm
Next time you get this problem in Illustrator, outline the stroke:
Object>Path>Outline Stroke.
It's a bit like creating outlines on text, it should iron this problem out :)
Post Mon Oct 25, 2010 2:20 pm
Andy,
In illustrator you can also set the preferences to 'scale stroke and effect' (under 'general' tab) - you can then keep as a stroke if you prefer for future editing.
Post Mon Oct 25, 2010 7:48 pm
Thanks guys
Return to Adobe Software
In total there are 109 users online ::
2 registered, 0 hidden and 107 guests
