Help with redrawing a shape
Post Tue Mar 23, 2010 5:31 pm
Hi All,
I am attempting to re-draw the logo attached here, could somebody tell me how to redraw the 'O' with the sharp out-crops? I am laying down a circle and converting to curves but I canny figure out how to get the sharp points on a curve, if that makes sense. Using Corel X3
Thanks from the home of the bewildered. :D
p.s I don't want this done, I need to learn how to do this...thanks
Post Tue Mar 23, 2010 5:38 pm
I would make a circle, convert it to object, convert it to curves.
Make a very thin rectangle then position it atop the circle where the sharp point should be. It shouldn't extend into the bottom of the circle. Then trim it. Delete the rectangle. Lock on a node beside where the trimmed area is to keep that point from being rounded. Then fiddle with it till it's right.
Then copy and paste the altered circle into the center of the first one and shrink it down to make the middle of the O.
Probably about a million steps too many but that's how I'd do it in Corel 12.
Or....just buy that damn ugly font.
Love....Jill
Post Tue Mar 23, 2010 5:40 pm
Hi Harry
You should be able to add a node with the pen tool, with the pen tool hold the alt key or one of those keys and it should put a little + next to the pen, then click on the stroke where you want to alter the shape, this adds a node that you can then simply (in this case and example) drag down to create the point in that shape (obviously hold the shift key so the node comes down in a straight line)
This is in Illustrator but would think it would be the same in Coral.
Warren
Post Tue Mar 23, 2010 5:41 pm
sorry to add on, drag the handles on the nodes in to the node to take the handles away and makes it a straight line, or amend the curve using the handle until you are happy with the shape.
Post Tue Mar 23, 2010 5:49 pm
Start with your circle,
right click - convert to curves
Select shape tool (second icon down)
From there you can;
double click to add a node
pressing c with a node selected will change it to cusp if smooth and vice versa
Press l to cahnge from curve to line and vice versa,
Double clicking a node will remove it
Aligning nodes icon will enable vertical or horizontal alignment.
By using these methods and having the bitmap as a template it should be easy to manipulate the shape as required.
Starting with a powertrace may give you a start.
Post Tue Mar 23, 2010 5:52 pm
:oops: sorry but just want to correct my post sightly, you will need to add in 2 nodes side by side to make that shape if it is not going down from an existing node, if you only add one node then it will make the circle oval and not just move down one piece.
hope that made sense but by the looks of it Coral is a bit different :-?
Post Tue Mar 23, 2010 5:54 pm
Illustrator again, but I'd use the scissor tool to cut the path, then just drop the node down a tad, then join.
Love the new avatar Jilly. Halloween was it? :D
Post Tue Mar 23, 2010 5:56 pm
redrawing
I might be missing something but I just convert it to a bitmap then use corel trace to draw the shapes usually looks fine??
uksignboards logo.cdr
as i've done here
(17.66 KiB) Downloaded 150 times
Post Tue Mar 23, 2010 5:59 pm
Now I use Signlab, Illustrator and have Corel on the system but this is a no brainer. To me some sort of vectorising software is the way to go as messing with all the nodes is just tiresome.
As a test I tried this in Vector Magic. It created a perfect vector image in exactly 11 seconds with no further editing required.
Why struggle?
OK it's not particularly cheap but the results with all manner of pictures are just stunning. It works even better than Signlab vectorising and has full auto mode or step by step, see what you get adjustments.
Over a period of time this has proved to be good value in the time it saves alone.
http://vectormagic.com/home
Now, I have posted the file just to show what was produced in just 11 seconds with ONE mouse click!
No, I'm not on commission!
File.ai
(13.61 KiB) Downloaded 151 times
Post Tue Mar 23, 2010 6:02 pm
Thanks a million folks for the prompt replies....Alan method has been spot on. :D
A trace would not be good enough as client wants a master copy. He has lost his original files.
I reckon it's looks where nurture rather than nature Jill....it was probably a good looking font until it met a designer!. :D
Post Tue Mar 23, 2010 6:08 pm
Harry I think the font is
http://www.myfonts.com/fonts/paratype/z ... armap.html
And it's $25.
Post Tue Mar 23, 2010 6:09 pm
Another vote for Vector Magic and I am not on commission either :wink:
When I bought it I complained about the exchange rate making the cost prohibitive so they gave me a $50 discount :D You can subscribe online for a monthly fee though.
Post Tue Mar 23, 2010 6:16 pm
Brilliant results from Vector Magic, however I do need to learn how to do these things as I guess the results wouldn't be as good from a really bad pic?
David: that file keeps crashing my Corel for some reason.
Thanks Jill, I wrongly assumed it was altered :o Thank the Gods of Typography and the ability to redraw, I don't have to have that on my system!!!
Post Tue Mar 23, 2010 6:22 pm
sorry
it may be because I've got corel 12 and 14 running on this damn machine here it is as an ai
uksignboards.ai
(21.77 KiB) Downloaded 110 times
Post Tue Mar 23, 2010 6:24 pm
Harry I took my new avatar pic after I looked up that font.
hahahaha
Post Tue Mar 23, 2010 6:37 pm
Jillbeans wrote:Harry I took my new avatar pic after I looked up that font.
hahahaha
:D :D :D evidently Madame! :D
Thanks for that David.
Post Tue Mar 23, 2010 6:54 pm
I downloaded the ai file, loaded ok into X5 - I'm pretty impressed with that result.
Return to Graphic Design Help
In total there are 83 users online ::
3 registered, 0 hidden and 80 guests
