how do i export files as ai or eps into corel or adobe?
Post Fri Dec 19, 2003 4:46 pm
I have been playing with a demo of E6. I can't figure out how to export as an ai or eps file type that can be opened in Coreldraw or Adobe Illustrator, it is easy in Signlab 5. Am I missing something simple? This would certainly put me off upgrading! Anybody able to help?
Marcella
:oops:
Post Fri Dec 19, 2003 5:07 pm
i think demo versions have this facility disabled
i have e6 full version and 5 and they both export
Post Fri Dec 19, 2003 5:28 pm
You can't export from the demo version. If you were able, people could get the demo version & a simple cut driver & have almost all the benefits of a full version at the fraction of the cost.
There are also easier ways to get from Signlab to Corel Draw without exporting.
Post Fri Dec 19, 2003 5:31 pm
In the demo the export function is crippled, however it seems that the only files type that are available in the full version are hpgl,dxf(line,polyarc,polyline and spline).
Signlab 5 gives the option of 18 file types including the above and also ai,eps,svg,gad.............
Marcella
Post Fri Dec 19, 2003 5:54 pm
18 versions in e6 the trial version does not install all options
Post Fri Dec 19, 2003 6:32 pm
Here is a list of SignLab e6.1 Import and Export filters that are included. This list is inclusive for the North American release, your mileage may very elsewhere. And if you have Adobe Acrobat or similar installed, you can always “print” to a .pdf based file.
Vector Export
HPGL Plot .plt
Adobe Illustrator .ai, .ps
DesignCAD (Line) .dc2
DesignCAD (Line_Arc) .dc2
DXF (Line) .dxf
DXF (Polyarc) .dxf
DXF (Polyline) .dxf
DXF (spline) .dxf
Encapsulated PostScript .eps, .ps
GCode1 .gc1
GCode2 .gc2
GCode3 .gc3
GCode4 .gc4
PostScript .ps
TXT (HDT) .txt
TXT (NewingHall) .txt
Gerber Edge .gad
Scalable Vector Graphics .svg
Image Export
PCX .pcx
TIFF .tif
Import (mixed)
Adobe Illustrated .ai
AutoCAD .dxf
AXYX RDY .rdy
Bitmap .bmp, .dib, .rle
CADlink Drawing .cdl
CADlink Region .rgn
Casmate .scv
Corel Exchange .cmx
Coral Metafile .cmf
Corel 3 PRN .prn
Dahedi .dah
DesignCAD .dc2, .dcx
DXF batch .dxt
EasySIGN .esw
Enhanced Metafile .emf
EuroCUT .job
FaxMan FAX images .fmf
Flexisign 5.6 .fs, .pd, .fd, .fc, .fe, .di
GCode1, 2, 3 .gc1, .gc2, .gc3, .nc, .cnc
GenericCAD .dwg
GEM/Ventura .img
Gerber GA/Omega .plt
Gerber Library Artwork .gca
GraphicCAD .dwg
GTP .gtp
H-Square Meistergram Logos .log
HPGL Plot .plt
InDepth Systems 3d Clip Art .id1
LetterArt .gnt, .sym
MonuCAD .dwg
PCX .pcx
Photo CD .pcd
SignBlazer ver1 .sbd, .sbl
Signmate 5.6 .sm
Sign Studio Drawing .ve
Targa .tga
ThermaZone .thz
TIFF Image .tif
USGS digital elevation map .dem
WordPerfect .wpg
Windows Meta .wmf
Post Fri Dec 19, 2003 7:31 pm
Thanks Bob, I hadn't checked the boxes in the filter menu!
Feel a bit stupid now!
Marcella
:oops:
Post Sat Dec 20, 2003 3:22 pm
Marcella wrote:Feel a bit stupid now!
Welcome to my life! Image
:wink: Image
Post Sun Dec 21, 2003 6:25 pm
Signlab to Corel
Brian you said there are easier ways to get a Signlab file into Corel?
Any chance you can post how it is done?
Thanks in advance
Marcella
Post Sun Dec 21, 2003 6:35 pm
Hi Marcella,
Just wondering why you want to get signlab files into corel anyway ?
Nigel
Post Sun Dec 21, 2003 10:03 pm
Hi Nigel,
I use Signlab 5 for all my design work but when I email customers a 'screen shot' of a layout I always use Corel, the difference in sharpness and colour clarity is huge.Try it yourself,if you have the same design on screen in Signlab and Corel it always looks better and sharper in Corel.
Marcella
Post Sun Dec 21, 2003 10:17 pm
Marcella,
could you not use a screen grabber like CorelCapture?
Cheers, Dewi
Post Sun Dec 21, 2003 10:32 pm
Marcella,
I see, never knew that before !
I used to have signlab on my pc, but it never got used, so I deleted it !!
So I can't try the experiment. I guess it must be to do with the colour profile settings in Corel vs Signlab but its a bit beyond me.
I don't think what Dewi said would help you in this cas because it will only capture what you have physically got on screen anyway, and so it will create a bitmap which will reduce the sharpness anyway, but I may be wrong.
Can't you use Corel to design in and then import the design into Signlab to cut it ? Or are you so used to signlab that isn't practical ?
Nigel
Post Sun Dec 21, 2003 11:06 pm
creativesign wrote:Marcella,
Nigel
heck Nigel, one of the reasons I won't leave Signlab is that it cost be so much and another program would cost almost as much again.
Personally, after paying so much I would persist with learning it, it's quite simple when you get to know it.
Post Sun Dec 21, 2003 11:15 pm
Gray,
My old Signlab (which has been deleted) didn't cost me very much... :oops:
Post Sun Dec 21, 2003 11:21 pm
Ah, I see the error in my subtle plan Nigel, screen capturing an image that the quality isn't too good on in the first place, then further degrading it during the transfer. :o :lol:
I know the transfer from Corel to Signlab can be done using EPS (many posts about it on the board), could the same not be done in reverse? I agree with Nigel though, it may be better to use Corel and transfer to Signlab when ready to cut if possible... saves the headache. I've found Corel is quite intuitive and easy to do complex stuff really quick, unsure how this compares to Signlab though as I've never used Signlab.
Cheers, Dewi
Post Sun Dec 21, 2003 11:30 pm
Well I agree, but I'm a bit biased I guess, not that I have shares in Corel Corp or anything - but I have used it since version3 on floppy disc !
I honestly find it so easy to use myself and to teach to others aswell, it's also unbeatable at flexibility in terms of what you can make it do with a little knowledge.
It's not perfect by any means - (try putting a contour round some text and then looking how many nodes there are on the curved sections for example !) but on the whole I would recommend it to anyone.
In my opinion, having tried to make my Omega/Composer software do the simplest jobs is a nightmare and I almost always end up back in Corel again 1st. Signlab is much better but I still think for overall flexibility Corel is a real winner albeit you cant cut from it as is.
Anyway thats just what I think !
Nigel
Post Sun Dec 21, 2003 11:43 pm
Dewi,
there is no need to use Corelcapture, simply hit the print scrn button on your keyboard and you can paste a screen shot into any application or email.
Marcella
Post Sun Dec 21, 2003 11:58 pm
Marcella,
You're right of course, but Capture will enable you to take a specific window only or just a select area and at a resolution of your choice, where the "printscreen" function only copies the whole screen at a low 72dpi? resolution.
Nigel
Post Mon Dec 22, 2003 2:01 am
This is going to be “scattered” response at best…
CADlink doesn’t offer “anti aliasing” inside the SignLab product, hence, that is why a “screen grab” from it will not render as “clear” as in CorelDRAW or any product that does support it. This is just one of a few real world examples as to why “we” would really like to see anti aliasing inside SignLab. This request was recently shared, at length, with one of the developers, so “maybe” sometime in the future we will see it realized. Then again, maybe not. The lack of this feature in earlier years and releases wasn’t as noticeable or impacting as it is in today’s “digital” output heavy environment.
Depending on the versions involved and method of installation, transferring from CD to SL can be as simple as a single “click” from CD to transfer it to SL, then another single “click” inside SL to place it. No need to save, export, open, import, etc. Just a simple transfer using the Application Launcher from within CD.
Nigel, Corel Corporation is no more, so no worry about the “shares” remark. Common stock shares were cashed out as the company was bought out by another company. And from one Gerber user to another, always glad to read of another success story! :roll: Yea right!! :wink: That software is good at showcasing Gerber hardware, not such much for showcasing the “designer”. Maybe someday, but I’m not holding my breath.
For anybody that is interested (and has access privileges), there is a small Corel Capture dem available at this link, https://www.uksignboards.com/viewtopic.php?t=1733. As Nigel states, it allows for much more flexibility then the using the Print Screen function inside the OS.
Cheers :)
Return to Signlab Software
3 registered, 0 hidden and 68 guests
David Hammond, Iain Pearson
