can anyone advise me on applying vinyl to van?
Lee Pawlett
Post Mon Aug 03, 2009 10:09 pm
AAAGGGHHHHH!!!!!!
Please has anybody got any suggestions to save me from a nervous breakdown. I am trying to cover a large area of a van in vinyl, it is not a wrap and l am using 3M 7-10 year vinyl. It doesn't matter what l try l can't get a good result the vinyl always looks pitted once l have finished, and l don't understand why.
I have tried wet and dry application. I am using a centre hinge. I am using a hard squeegee. Any idea's, the only thing l can think is if the application paper is affecting it, is this possible or could it be something else.
I need to resolve this for the morning so any help would be greatly appreciated
Lynn Normington
Post Mon Aug 03, 2009 10:11 pm
maybe show us a pic of what you are trying to do :roll: or at least say make and model
Lee Pawlett
Post Mon Aug 03, 2009 10:17 pm
It is a ford transit long wheeled base 09 plate
Post Mon Aug 03, 2009 10:23 pm
Can't really comment for sure without seeing a picture of the problem.
But be aware - the glue takes up to a week to finish flowing and bonding. The surface appearance will almost certainly improve over time. Are you sure you're not being too critical of your own work?
Lee Pawlett
Post Mon Aug 03, 2009 10:37 pm
I can't take a picture until the morning as l have given up for tonight. Will take a picture in the morning and post it. I know a certain amount will settle but this is really too much to be acceptable to give to the customer like this.
Post Mon Aug 03, 2009 10:38 pm
why are you using app tape?
DavidRogers
Post Mon Aug 03, 2009 10:43 pm
Best advice I can give you is don't use application tape if at all possible.
Use a felt or (my favourite) AVERY blue 1/2 felt squeegee - works a treat.
And do it dry if you can - wet as a last resort - and hope the air / van temperature stays low to keep the glue tack reduced to make for an easier application.
Chris Wool
Post Mon Aug 03, 2009 11:10 pm
in the area you are having most trouble i would try a smaller bit, easy to handle etc, so you can see if its technique or other problems.
Lee Pawlett
Post Mon Aug 10, 2009 2:12 pm
how do i insert a picture to show you where im going wrong?
George Elsmore
Post Mon Aug 10, 2009 2:19 pm
put it in the file swap forum where it allows you to upload
Jon Marshall
Post Mon Aug 10, 2009 2:31 pm
I'm not sure what you mean by 'pitted'. However, i have seen freshly applied vinyl that has a lot of squeegee marks and small bubbles in look absolutely perfect a couple of weeks later so maybe it's not as bad as you think.
Cameron Steer
Post Thu Aug 13, 2009 10:27 pm
Hi There,
How long ago was it painted? can take as long as 3 weeks to cure , if applied too soon the solvents can outgas causing bubbles etc, if its a cast vinyl it should be thin enough for them to escape through in a short while.
Martin Oxenham
Post Fri Aug 14, 2009 11:08 am
Are you doing this outside ? If so then the pitting is airbourne dust, you need to wipe it again as you fit it. We get this problem when the weather is good but a little windy.
Gary Thomas
Post Sat Aug 15, 2009 12:41 am
Bubbles and the Pits!!
Must say, i have battled with this for years - i am but a mere novice compared to some of you guys and I fit graphics to vehicles maybe once a week on average but would love to get that 'new fresh paint look' using vinyl!! - I have persevered with applying dry and would love to master that technique but i must admit i get better results when applying wet -
light spray to panel then light spray to vinyl - once the vinyl is applied I then soak the application paper (for large panels I try to avoid application paper if possible) - After a few minutes the application paper should come away fairly easily, in some areas literally fall away - I use a felt squeegee to push out excess water and push the vinyl into the recesses. - Today I finished a small panel 50cm x 150cm - this was completely smooth all but a few pits left from the paint job on the panel. -
The majority of vinyl work I carry out on vehicles is left with those annoying small air bubbles?!!! - But give it a week or two then these do disappear - It just makes it a bit awkward explaining to the customer and trying to convince them that all will be well - i promise (?) :o
In total there are 82 users online ::
3 registered, 0 hidden and 79 guests
