Software issue means my graphtec will only cut tiny numbers!
Post Sun Jun 21, 2009 8:31 pm
this is probably a really stupid question. i have a graphtec CE5000 120 cutter and i am using it with vinyl master pro. When i output my work to cut the cutter just cuts a series of tiny numbers.
I'm sure it's a software issue as the software which came with the cutter works fine.
I've tried the cutter on a mates flexisign now and it also only cuts a series of tiny numbers.
Is there something i am not setting up correctly in these softwares which causes this to happen?
I would really appreciate any help as this is driving me slightly crazy.
Liam
Post Sun Jun 21, 2009 8:35 pm
You are probably using a HPGL diver when it should be GPGL or vice versa.
Post Sun Jun 21, 2009 8:51 pm
thanks Brian i will give that a try, must be something simple like that.
Post Sun Jun 21, 2009 9:31 pm
It will almost certainly be a language problem if the numbers are tiny single line ones (ie ones that you cannot weed) You can switch the Cutter between HPGL & GPGL so can change that rather than the software if you prefer.
Post Mon Jun 22, 2009 8:40 am
I reckon Brian is right, Cutting Master comes with the Graphtec and that only works with gpgl. When I use Signlab that driver is hpgl.
Post Mon Jun 22, 2009 11:57 am
Thanks both for your advice i'm going to try this later when i get chance and will let you know how i get on.
Liam
Post Mon Jun 22, 2009 3:23 pm
Ok thanks very much to you two for your advice as it helped to solve the problem a great deal. :D
Let me just explain exactly how i sorted it in case anyone else has the same problem and finds this thread, i don't want to just take from here so i will try to contribute-
First of all i downloaded the full manual for my graphtec cutter from their website. Then i found out how to change the cutters language setting to HPGL. I then had to make sure my software was communicating in the same language.
Then finally i found out the changes only took effect when i switched everything off (cutter and computer) and restarted them. Now everything is working fine.
Thanks again!!!
Liam
1 registered, 0 hidden and 61 guests
