can anyone help with my 6 year old roland pnc-1200 please?
dave48858
Post Thu Nov 06, 2003 4:45 pm
I've been running a pnc-1200 for 6 or 7 years now, I lost my manual and I remember it had something about exactly what it is doing now. when I do my test cut with the little cross, the corners aren't square any more, I don't know how else to say it, but it's getting sloppy. Any body with the pnc-1200 manual or pnc-1200 experience, please help.
Mike Antrum
Post Thu Nov 06, 2003 11:23 pm
PNC 1200 Blade Offset
Hi Dave,
The most likely reason that you are having this problem is that the blade offset is set incorrectly. The correct blade offset for original Roland vinyl blades is 0.250 mm. However, if you are using other blades the rule is:
If the corners are rounded - increase the blade offset.
If the corners are 'pinched out' - decrease the blade offset.
So how do set the blade offset ?
On the display where you set the pen force (gf) the item on the bottom left hand corner is the blade offset. Use the left and right arrow keys to put the flashing cursor over this item, and use the up and down arrow keys to increase or decrease the value. After setting the value press 'Enter' to confirm.
On another note, if the blade offset is set to zero, the word 'Pen' is displayed in the top right hand corner. If it is any value other than zero, the word cut is displayed in the top right hand corner.
Hope this helps,
Mike
Post Fri Nov 07, 2003 11:04 am
Somebody posted a link to an online manual place for Roland manuals, I think it was Alan Everleigh ? Al you reading this ?
dave48858
Post Sat Nov 08, 2003 7:53 pm
6 year old roland pnc-1200 --- help
Ok, I tried .2mm, .225mm, .25mm, .275, & .3mm. As far as I can tell, all the test cuts identical. Does this mean I am way off? Does this mean I'm due for a new plotter? Or should I try to get a little more radical than just .025mm off the oridginal setting by Roland? A little more advice would be greatly appreciated
Post Sat Nov 08, 2003 8:38 pm
Steve Broughton wrote:Somebody posted a link to an online manual place for Roland manuals, I think it was Alan Everleigh ? Al you reading this ?
Sorry Steve not paying attention again, story of my life :oops: :lol: :lol:
Here you go http://www.allgraphicsupplies.com/manuals.shtml
Post Sat Nov 08, 2003 8:50 pm
no your machine is not knackered...
if not for the reasons above. i would expect it is the actual mounting of the blade holder. this has happend to me in the past, we have had 3 roland machines. the part that holds the blade had actualy come a little loose. this causing the rounded corners etc. make sure all is tight. then check the actual part that holds/grips the blade is tight too.. i bet its this!
this is normaly found on machines that have been use alot or, have been churning out work for many months. :wink:
dave48858
Post Sun Nov 09, 2003 9:09 pm
I got it working, Thank you all very much for your help.
Post Sun Nov 09, 2003 9:22 pm
good to hear mate.. what was the prob in the end?
dave48858
Post Wed Aug 24, 2005 11:30 pm
wow, ok, I changed over from using a open blade to an enclosed adjustable depth blade holder, the blade had broken off, but was still cutting, just not where it was supposto be. Thanks again for all your help guys. BTW, I upgraded to the proII EX and I love it.
Post Wed Aug 24, 2005 11:33 pm
wow ye...that took a long time.... :D :wink: glad you finally got it sorted :P
Return to Roland Cutters
In total there are 26 users online ::
4 registered, 0 hidden and 22 guests
Chris Wilson, Pane Talev
