versa camm snagging full roll of vinyl
Post Thu Nov 27, 2008 12:37 pm
Hi all
Can any one help me with this when i put a full roll of vinyl in the printer for a cut only job it will feed fast and it snags the role hard causing it to error is their any settings that i can change rather than spooling off a load of vinyl by hand to reduce the weight?
Thanks Neil.
Post Thu Nov 27, 2008 1:01 pm
Is your brake on or off?
Post Thu Nov 27, 2008 1:12 pm
hi,
we have had a similar problem with some heavy rolls. Are you using the plastic inserts? They help, make sure brake is off, and we always unravel a couple of meters of material to help with the weight issue.(and with some heavy lonas, manually pull when it is running through)
If it is happening all the time: motor error message then speak to the person you bought the machine from, for instructions on ho to check if the motor is knackered it can happen.
the other option is to disable the automatic pull through option, but if you do this you must make sure that A you have enough media, and B it is alligned correctly if it is a long or very wide print.
hope that helps, it drove me barmy for a while!!
Dan
Post Thu Nov 27, 2008 2:37 pm
hi i have got the brake off i will give the plastic inserts a try
Post Thu Nov 27, 2008 3:24 pm
Hi Neil,
Try slower setting. Had the same problem when we got our new cutter, we had it on a fast speed. 50M roll and it kept snagging, we lowered the speed and it works fine.
Pulling out lengths of vinyl at start can some times twist the vinyl when it reaches the end of the pull out ( hope that makes sense ) and cause jamming.
Vic
Post Thu Nov 27, 2008 7:59 pm
I have slowed down the up speed setting on the printer and that seems a lot better thanks for all you help and quick replies
Post Thu Nov 27, 2008 10:26 pm
dont know if its on the versacamm but on my soljet you can also adjust the pen up speed, which is handy.
Return to Roland Printers
5 registered, 0 hidden and 68 guests
David Hammond, David Wilde, Russell Pavey
