Roland VersaCamm
Post Tue Sep 16, 2003 7:20 pm
Roland VersaCamm
has anybody heard or seen this new machine in the UK yet.
http://www.rolanddga.com/products/printcut/versacamm/
it seems from the US site to be very good, and priced at under £10k
and cheap running costs.....interesting times ahead
Post Tue Sep 16, 2003 7:37 pm
That seems like a very interesting machine, although I haven't yet heard of it in the UK.
(oops - It's actually featured on the UK website:-
http://www.roland.co.uk/gr10/dg/versa.asp)
Funnily enough, about 15 months ago a Roland engineer told me there would be a solvent inkjet on the market soon priced on a par with the colorcamm but with much lower running costs.
If it's as good as it says - this will certainly interest me :D
Post Tue Sep 16, 2003 8:12 pm
Hmmm looks like an interesting machine, but I bet when it's available in the UK the dollar sign will be replaced with a pound sign = £15,000 + VAT, (:)
Post Tue Sep 16, 2003 8:28 pm
looks like a ..
I went and saw a "uniform grenidier" printer at BP graphics recently and was told the "jnr" version will be out this Christmas. The machine was effectivley a modified Roland of some sort. Price was quoted as around 10k. Its a eco-solvent print and cut, same specs as the VersaCAMM I think. I got hold of some samples and I got to say the quality is excellent.
Ink cost is about £3.50 per square metre.
Gotta say Iam tempted to get one when it comes out.
Post Tue Sep 16, 2003 9:22 pm
Mark,
I'm also having a look at this machine soon too - but i posted a bit on it before i knew what it was, and apparently there is a deal where you don't pay for the machine - you just need to buy two sets of ink per month, though the disscusion is who much your actually gonna use it, to get throught that much ink??
Post Wed Sep 17, 2003 6:01 am
I have seen the Versacam and had some experience with it and its a real little gem - its really affordable at about R100 000 here and R12 = GBP1 - so Im sure it will be under 10k.
I have its much bigger brother - the Soljet Pro II.
Its a 4 colour machine , not a 6 colour , doing CMYK - it prints to 1440 dpi , but in reality the profiles only go 720 x 1440 - one would very seldom use the 1440x1440 mode anyway - the reason it doesnt use 1440 x 1440 is that it uses a new inkset and heater - and 1440x1440 deposits too thick an ink layer for it to dry properly. I might be wrong here , there might be upgrades to the RIP etc
It's not a blindingly fast machine , the big soljets print about 4x faster. This is not a problem unless you are pumping out huge amounts of graphics.
Inks are the same as the other rolands and cost about $75 a 220 ml cartrige.
We work on about 200-250 sq m for a 12 cart inkset - so I would imagine that one would get about 80-100 sq m for a 4 colour set , IE about 800 sq ft for $300 - about 40 pence per sq ft and that is conservative.
You can expect to print round 2-4 sq m an hour at a medium to highish resolution - cutting is pretty fast too and very very accurate.
You can actually print , overlaminate and reload (the machine works it all out for you) and then cut.
The 4 colours vs 6 are not much of a problem unless you are doing "art" type printing , colours are nice and vibrant , blacks are black and not muddy
What can it print on - well most uncoated vinyls , most papers , most self adhesive papers , some Canvas , most fabrics and poly weaves , some holographic foils , some really exotic subtratres like laserable spectrum lite foils , clear vinyls , backlit , most banner materials , scrim banner , fire retardant banner , plain banner , perforated films , some cold laminating films , acetates etc.
Results are variable on uncoated media , depending on the profiles used , a lot of stuff doesnt have a profile and one has to fiddle - using rolands coated media gives better results than uncoated in terms of smoothness of print. This too is pretty academic unless you use a loupe to examine the print (I do!!)
Most stuff comes out dry to the touch , some are slightly tacky , but dry in a few minutes , unlike the older rolands whose prints came out quite wet.
It is a very dandy affordable machine and is going to shake up the industry a bit - it empowers those thatr dont want to spend $30k on large format to compete in the industry.
The RIP alone , which is a Wasatch RIP is excellent - one of the best around , its quick and has some great features and albeit it's not the FULL wasatch rip (being customised for roland) it has most of the features.
There is a nesting feature that will optimise print material , it takes the various shapes you cut and fits them as close together as possible to conserve space.
The machine is maintenance free to all intents and purposes , you just clean it - no flushing pipes , messy inks etc etc.
It doesnt have a network card , but a USB port and on big big files , this slows down tranmission a little , but its not a problem (It might be if the machine printed faster)
Its as good as just about any large format printer and a lot better than some at 5x the price. It's obviously not meant for digital shops that churn out 100's of sq meters a day - the smaller size also makes handling rolls of media easier.
One thing I didnt look at was whether it can adjust head height to print on media up to 1mm thick like the bigger machine does , the specs dont indicate a material thickness.
Im not a roland agent , and in fact am sort of wary of roland promises but this looks ok to me - I am not sure what place the roland PC60/600 will have with this product out ?
I would take the Dealer a CMYK image and a "spot" colour image and ask them to print for you to see how the solid colours are printed , their accuracy and how it handles shading and fades on the CMYK image.
I think its worth a look and is a better bet overall bang for the buck , than the bigger machines , its limitations vs them are not worth 2-3x the price.
Post Wed Sep 17, 2003 6:28 am
I forgot to add this
durability : on uncoated media you tend to destroy the vinyl when scratching with a sharp object to get print off , uncoated vinyl also withstands the wet finger rubbed vigourously overt the print test - some solvents remove the print instantly (citrus oil cleaners are deadly) - as to UV stability , well most inks are uv stable for their rated life.
If I was doing anything like vehicle wraps , I would use some sort of lamination or coating , same with anything that will be handled a lot
On Coated media (and it DOES print a little better on coated) the media and coating will determine the resistance to damage - some are hardfy and some are VERY fragile.
If the print is tacky when it comes out touching it reduced its gloss , but doesnt smear it much. , some Medias actually dont work very well , like the shiny silver polyester vinyl or reflective vinyl , however even if the print is slightly wet or slightly pooled (IE cos its wet it sort of clumps a little) it still does dry pretty durable if not messed with.
One thing is that the RIP on my big machine has a 2 and 3x overprint function for backlit stuff - IE a much denser ink laydown - this doesnt work as well as a single strike (normal) as it tends to blur the detial a little , I am being real niggly here , but its there.
As I was writng this post , I tried a print on sparkly lamination film , a sort of cold pressure lamination matt film with a slight sparkle used to finish prints , it worked beautifully - Im sure there is some sort of application for digital printing on laminhation films? If I can print onto something using the soljet , it can be printed using the Versacam - same rip , same ink , same heater technology.
Not sure whether it would work with the hot films tho
Return to Roland Printers
