How to install Foamex
Gray.Hodge
Post Sun Sep 07, 2003 7:19 am
Can 10mm foamex sheets be glued to a concrete wall and have them stay there? I'm concerned about expansion under heat.
The sections I need to fix may be a long as 6m (18 feet) by 500mm (20")
I am hoping not to have any screws showing from the outside.
thanks for any help and advice.
I'll post a piccie of the design soon.
Kevin Flowers
Post Sun Sep 07, 2003 4:23 pm
Gray
basic general rule i work to is to always install some kind of mechanical fixing in minimal quantities along with the bonding. This is for two reasons one if the bonding does break free for whatever reason you don't look so much of a prat. The second being the real reason it states some where that mechanical fixings should be used as additional anchoring for bonded panels so that if the bonding gives way in a fire the mechanical fixings will help to stop the panel falling and blocking an exit etc. Obviously it does depend on certain circumstances. Hope this helps
Kevin :cool:
Graham Scanlan
Post Sun Sep 07, 2003 5:55 pm
2 points,
10mm will expand and contract and will need fixings in place to allow movement.
if using solvent adhesive if the solvent gassing off has nowere to go it will come through the foam and cause the sheet to buckle (i have seen this)
and on another point why not try 2 or 3 mm di-bond/alucolor/rynabond etc
a lot less movement if any
Post Sun Sep 07, 2003 6:48 pm
moons right! i would opt for the dibond etc solution if possible...
one problem you may have though. if you are not fixing these sheets with anything other than silicon. you may find the sheets will slide before drying. do you have something that sill hold these in place until dry?
if it just comes down to, "you want to hide the fixings" then why not raise the whole panel on locators/fixing studs?
i have did this in the past and it looks good, a little bit different also.
:wink:
Gray.Hodge
Post Mon Sep 08, 2003 11:53 am
Thanks all for the info.
Choice of material is largely determined by what is easily available.
I have two main choices:
1. Foamex. No coating required, lightweight, more expensive, and subject to expansion.
2. Signboard, a timber composite board, 5mm thick, fairly light, needs painting, no expansion problems.
Rob, I would love to know is more detail how you raise the panel on locators, that sounds a good idea.
Have you done any demos on that method?
Lorraine Buchan
Post Mon Sep 08, 2003 5:57 pm
How about the idea of using the fixings that are used to fix pictures flat to the wall??
It just poped into my head while reading the post, so it might be completely useless.
you would still be able to see the fixings at the side of the sign but not physically through the sign.
Fat Bob
Post Mon Sep 08, 2003 9:00 pm
Hi Gray
If you dont mind the panels standing off the wall the then a system called split batton may be your answer.. if you have a table saw that cuts wood at an angle this is a piece of cake. slice a full length of 2 x 1" tiber at about 45 degs. Screw and glue two lengths on to the board and then screw one on the wall so you can HOOK the panel on it.
Mark where the second rail has to be remove board by lifting straight up
now screw the second rail on. rehang the board. if you have placed the rails about 3" from the top and the bottom of the board it will now be possible with a long drill bit and screw driver to put a couple of security
screw through the rail on the board and into the wall from underneath or
the top this will stop anybody accidently lifting the sign up enough to make it fall of the Hooks. This is Quite Hard to Explain so if you need a picture e mailed let me Know.
Regards.....FB
Lorraine Buchan
Post Mon Sep 08, 2003 9:56 pm
Bob your post has lost me completely, Any chance of posting a small demo??
Simon Clayton
Post Mon Sep 08, 2003 10:14 pm
Good thinking; that Bob..
we have used that method, but used foamex batons fixed to both the wall and the foamex panels.
Something to do with expansion of different materials.
Simon
Gray.Hodge
Post Mon Sep 08, 2003 11:28 pm
I think I know what you mean Bob, I did something similar out of folded steel, but since the sign is very long and narrow, and high up, that method might be awkward.
Post Tue Sep 09, 2003 12:24 am
hi gray
the panels are raised just like a raised flat cut letter is raised using a locator/stud glued to the rear. spaced out on the back something like this:
just tape a paper template on the wall then drill the holes for the female locators/cups to be applied then snap into place the panels. :wink:
Gray.Hodge
Post Tue Sep 09, 2003 2:14 pm
Robert, by "locators" I believe you are referring to a product that I know nothing about and/or is not available here.
Can you give more detail on this product? thanks
Post Tue Sep 09, 2003 3:23 pm
Gray
I believe Rob’s referring to the locators he used in his demo https://www.uksignboards.com/viewtopic.php?t=1855
They come in two parts and pop together like a press-stud, the part not shown in the demo is the piece that fits to the wall or whatever. It’s like a small section of tube closed at one end, with just a small hole through which you pass a screw into the wall.
Shout if you need a picture.
Here you go http://www.snapfix.co.uk/
Gray.Hodge
Post Tue Sep 09, 2003 11:28 pm
cheers Alan, I'll have a butchers.
Lee Attewell
Post Wed Sep 10, 2003 2:14 am
Hey Gray,
If you find out about these locators, post the details please. I've tried to find them as well but with no luck.
Better yet...If Rob can give us the name of the manufacturer, I'll give them a call and find out an Aussie Distributor.
Post Wed Sep 10, 2003 3:15 am
hi gray/leeroy
ill see if i can find anything more about them. i dont actualy know a manufacturer of them, simly because lots of places here supply them.
im very surprised they arent common over there.. maybe just under a different title.
leave it with me anyway. ill see what i can do.
funny enough i have a few demos im working on at the mo.. two have locators in them. :lol: :wink:
once you see them im sure you will both realise just how simple they are, but effective when used. :wink:
Lee Attewell
Post Wed Sep 10, 2003 5:29 am
Sweet Rob, I'll look forward to that.
L
Chris Wilson
3 registered, 0 hidden and 57 guests
Chris Wilson
