Enlarging jpg Images WITHOUT Losing Clarity?
John Cooper
Post Sun Apr 27, 2008 3:23 pm
Hi Guys
I have a stack of jpg image files that look great great. I want to enlarge them so they still look good! I know the usual result is horrible blocky/fuzzy edges.
These pictures are destined for T-Shirts so the images don't need to be of photo quality.
Is there any software that is designed for this purpose?
Martin Grimmer
Post Sun Apr 27, 2008 3:40 pm
John,
I use photozoom pro after a recommendation on here. Seem to recall about £100.
http://www.benvista.com/main/content/co ... ozoompro_1
Not perfect but does a very good job.
You can also check out Genuine Fractals - tested that a long time ago and was pretty good.
Hope helps
Post Sun Apr 27, 2008 6:43 pm
John, sometimes you can get away with just increasing the resolution in a photo program, especially when they aren't going to be blown up that much, can you post a sample image, maybe you will get some examples of what can be done.
Post Sun Apr 27, 2008 6:50 pm
alien skin do a plug in called Blow up
BlowUp offers the highest quality image resizing available, better than bicubic interpolation and any other third party solution. BlowUp makes advanced image scaling easy, preserves smooth, crisp edges and lines, and creates four times (1600% area) enlargements from any image without jagged artifacts or halos. In some cases, BlowUp can enlarge up to six times (3600% area) without obvious artifacts
John Harding
Post Sun Apr 27, 2008 8:52 pm
oooh somones swallowed a dictionary :D :D
Post Sun Apr 27, 2008 9:06 pm
Amazing what copy and paste can do John.
If you look at the text you can tell it did not write it as the spelling is correct and has punctuation in the correct places.
Shane Drew
Post Mon Apr 28, 2008 12:07 am
Martin-G wrote:John,
I use photozoom pro as well. Excellent for doing really big stuff. Corel Photopaint X3 is good enough to enlarge most Images for printing to shirts and stuff though.
Gareth.Lewis
Post Mon Apr 28, 2008 2:17 pm
I tried photozoompro myself a couple of months ago. Then I tried to email the increased res. file to my outsourced large format printing co. in England.........no way, hose.
If you have in house printers all well and good but any clues as to what to do if you havent?
Martin Grimmer
Post Mon Apr 28, 2008 4:04 pm
Gareth Lewis wrote:I tried photozoompro myself a couple of months ago. Then I tried to email the increased res. file to my outsourced large format printing co. in England.........no way, hose.
Gareth - if you have photoshop, you could try the "save for web". This gives you a preview as to what the finished version would look like saved at a lower level (guess more compression) - you can normally dramatically reduce file size this way. If all else fails, burn larger file to disk and post to your wide format printers - will only take extra day (although can be a pain if done too often).
Steve McAdie
Post Mon Apr 28, 2008 4:15 pm
Some printers if not all should be able to enlarge image for you. Some may charge for this others might not. I have sent disks before in the post only drawback is it takes a day or so longer than e-mailing. I prefer to do any scaling myself but that's cos I'm a control freak
Ian Higgins
Post Mon Apr 28, 2008 7:11 pm
increasing pics
The latest Signlab Print & Cut has a handy tool for doing it
Alexis Davis
Post Sat Aug 09, 2008 1:15 am
I find just resampling using the photoshops bicubic smoother does a good enough job, obviously it can only blow up so much but seeing as you only want to blow up to go on tshirts Im sure that should do the job if its not ridiculously small.
Jason Xuereb
Post Sat Aug 09, 2008 6:44 am
If you are going to use photoshop increase the image 5% at a time. It reduces the distortion compared to trying to increase it by 100% in one go.
We use photozoom pro here though.
Although we did a banner the other day 5m by 5m and scanned it in from a negative.
Graeme Harrold
Post Sat Aug 09, 2008 8:13 am
Done something similar in Corel Photopaint. Taken a small image and changed the dpi setting first, then altered the size in mm to what was required. It does help with enlarging, but can make the image a little fuzzy, as if it has a soft focus.
Jason Davies
Post Sat Aug 09, 2008 8:55 am
You could even print them out in hi-res and re-scan at a high dpi, problem solved.
Jason
Neil Herbert
Post Sat Aug 09, 2008 9:54 pm
Try www.cutesendit.com worth signing up and downloading free desktop program.
Hope this helps
Neil
Peter Dee
Post Mon Aug 11, 2008 8:37 am
You can also send large files over Skype.
http://www.skype.com/intl/en-gb/allfeat ... etransfer/
Lee Attewell
Post Mon Aug 11, 2008 9:42 am
We send massive files via Windows messenger...Works well :-)
Rodney Gold
Post Tue Aug 12, 2008 6:20 am
Use Xnview , a freeware utility , resize uses the Lanczos algorithm , it has many other algorithms/options too.
Aso a great Coreldraw and other graphics viewer
http://www.xnview.com
4 registered, 0 hidden and 59 guests
Kevin Mahoney, Noel Kearney
