Printing using backlit vinyl - problem
Post Tue Feb 26, 2008 5:17 pm
hi,
I tried printing using my cadet today onto backlit vinyl, I canceled the job after the first 50cm as the print was kind of showing a mottled or bubbled effect, obviously through a lightbox this wont be anywhere near acceptable, with the vinyl costing near on £7 per metre Id rather get it right than waste more material. he profile I used was for gloss vinyl at a very slow speed. Any advice appreciate. cheers graeme
Post Tue Feb 26, 2008 5:54 pm
Hi there,
Is it Self adhesive vinyl ? do B&P have a profile for a specific grade?
Rob ( lambie) has a Grenadier so i presume uses the same inks etc , he uses a backlit polyester film and gets good results , maybe thats worth a try and check with rob what profile he uses?
Hope this helps
Post Tue Feb 26, 2008 5:57 pm
Graeme. Probably completely different because of the inks but when I had my encad I had a completely different profile for backlit film to that of normal gloss vinyl.
Post Tue Feb 26, 2008 7:14 pm
thanks guys, cameron do you stock a product that would do this job on my cadet, I'm normally 100% using europoint for my supplies but went elsewhere :oops: !! for this. If you could let me know, thing is its only a5m job so no need for a 50m roll.
graeme
Post Tue Feb 26, 2008 8:01 pm
Vinyl
You need to use a profile for backlit vinyl... if you do not have one use one for Matt it will be better than the gloss profile
Ian
2 registered, 0 hidden and 72 guests
