which ruler for vehicles?
James Martin
Post Mon Aug 20, 2007 5:08 pm
Hello
I usually use a measuring tape to sort out some aligning issues when fitting vehicle graphics but the aluminum hook sometimes has left marks on the paint work. :oops:
Is there a plastic version out there that anyone knows of, or what else do you uses.
Got some nice white vans to work on this week.
Don't want to be doodling on them with my ruler.
Brad Mulock
Post Mon Aug 20, 2007 5:26 pm
Ruler for vehicles
Hello James,
I have stuck plenty of vans and other vehicles. I use various methods of marking out the setup lines.
I have experienced the same problem with the steel tape measure so now if doing a vehicle i use my miss's sewing tape measure. You know the type. Normally found in the bottom of a sewing basket rolled up in a small circle.
I have found these also benefit me but allowing me to measure around trimmings etc.
Hope this helps.
Brad
Post Mon Aug 20, 2007 5:40 pm
James, I have a small (3 mtr) tape measure that lives in my fitting box and is only used for vehicle graphics.
Same as my squeegee for floodcoating I have double sided taped a bit of velvet to it.
I just cut a small peice of velvet and double sided taped it over the hook, that way I can still use the hook but don't have to worry about it marking anything.
Sewing tapes still have metal ends that may scratch and they do stretch so I wouldn't use one myself but obviously Brad seems to manage OK with it.
Steve Underhill
Post Mon Aug 20, 2007 7:06 pm
put some hot melt glue on the end in a very thin layer it will dry as hard as plastic and wont then mark the paint
Graeme Harrold
Post Mon Aug 20, 2007 8:37 pm
Ive applied heat shrink to the end 10cm of mine.......
Ian Bingham
Post Mon Aug 20, 2007 9:12 pm
quick tip
someone at roland gave us, make and use you own magnetic tape from off cuts of magnetic sheet we use for signs, about an inch wide and 6 ft long, make a few so they can be used for aligning and measuring
no marks, one man use, great for lining up
Ian
James Martin
Post Tue Aug 21, 2007 2:44 am
That's a nice wee handful of ideas there lads.
I can see myself trying each of them at some stage.
cheers! :D
Post Tue Aug 21, 2007 10:11 am
As Ian said, off-cut of magnetic, about 2 inches wide, with measurements stuck on to one edge. I used the end of an adhesive bench measure (bought from Jag, I think) which was surplus.
James Martin
Post Wed Aug 22, 2007 12:25 pm
Tks Lorraine,
I was in visiting a friend of mine this morning and hes given me some felt that has a peel away adhesive side, said he got it in John lewis's in glasgow.
Just stuck a bit on the end of my tape and its looking good.
Next time I cut some magnetics I'll be building a couple of rulers with it mind you: I find I measure things far to many times, especially on vehicles.
Any complimentary devices to get things running smoothly has got to be a good thing.
Derek Heron
Post Wed Aug 22, 2007 12:53 pm
the felt you mention is also great for the back edge of scissors for when your cutting graphics when taped onto van sides etc ,so it doesnt scratch
i also use helix l16 shatterproof rulers clear blue and flexible for measuring on vehicles
derek
Dave Bruce
Post Wed Aug 22, 2007 6:51 pm
I use a Fisco Big T tape which has a rubber end and comes on its own clip so you don't keep ruining your trouser pocket clipping it on and off. You can buy them from Jag supplies or good hardware stores.
Matt Hards
Post Wed Aug 22, 2007 7:07 pm
I have a plastic white 1 metre ruler that i use most of the time. nice and flexible, no marks.
1 registered, 0 hidden and 56 guests
