how can I get just the outer line of the stroke?
Post Thu May 24, 2007 6:37 pm
Hi all
Quick question for illustrator just started cutting from it
If I put a Stroke on the font to give it a larger appearance then outline the font how can I get it just the outer line of the stroke is my cut line I have tried outlining stroke but then I have about 3 paths.
thanks guys
martin
Post Thu May 24, 2007 6:50 pm
Use the direct selection tool (the white arrow) to highlight the additional lines you dont want. Ctrl + Y will get you in and out of outline mode quickly to check. (think you can also click on a node in outline mode with the direct selection tool, delete once to delete the node, press delete again and it will get rid of remainder of line).
Hope helps.
Post Thu May 24, 2007 10:31 pm
It sounds like you are doing it right - outlining the strokes.
After that, like Marts said only - put a little more simply - select the paths you DON'T want, and delete them.
Post Fri May 25, 2007 2:09 am
create an offset path save it to a seperate layer and only cut that one.
Post Fri Aug 17, 2007 1:58 pm
Hi Guys
The easyest way I find to do it is to -
- create you text with outline
- outline font
- outline stroke
- select all and un-group
- in the pathfinder pallet click add to shape area then expand
sorted, dont know if this is easy for you but saves selecting individual letters
mart
Return to Adobe Software
1 registered, 0 hidden and 104 guests
