Help! How can I get rid of
Post Fri Jun 09, 2006 1:13 pm
the white surrounding a picture, so that I only have the image left?
The image needs to go on a coloured background, with no white edges.
Any advice much appreciated.
Post Fri Jun 09, 2006 1:19 pm
Lorraine,
Is the image a Jpeg? and what software are you using? If you're using photoshop, you should be able to set the background to transparent. I'm not 100% on how, but I'll have a look later when I get back. I think if you "select all" and "copy" then do "File - New" there's an option for transparent background. Again, I'm not 100% on if that'll work as you want it to, you might have to select the part of the image you want and then copy it to the new image.
Sorry to be vague! Having a bad memory day!
Adam
Post Fri Jun 09, 2006 1:25 pm
Hi Adam, thanks for the quick reply.
I have Signlab, Corel 12 and Photoshop, have tried all of them but Photoshop is really b*ggering around, keep getting a 'no disk in the drive' message which won't go away, and prevents work. Don't know why, as it never used to happen. I really need to remove & re-load I guess, but don't have the time. :evil:
Post Fri Jun 09, 2006 1:29 pm
What format is the image?
Adam
Post Fri Jun 09, 2006 1:33 pm
if its a simple shape use the node tools in coral to remove unwanted areas of the pic. in photoshop its a lot more involved.
Post Fri Jun 09, 2006 1:37 pm
If its just a white border use the crop tool in Corel Draw
Nick
Post Fri Jun 09, 2006 1:45 pm
Adam
They are Jpeg's
Post Fri Jun 09, 2006 1:50 pm
Lorraine,
can you post a picture - slightly difficult to visualise
martin
Post Fri Jun 09, 2006 1:51 pm
Ok, I'll have to put in another forum...
I now have uploaded it to the file swapping forum, thanks all.
I have been trying your advice too, Corel won't give me the crop option....
Post Fri Jun 09, 2006 2:24 pm
Loraine in signlab, its dead easy. several ways and it depends which modulesyou have in your version.
Method one, using node edit draw round the pic make the resulting shape a colour then select the jpg and the shape and use the clipping tool, job done.
If you have colou phototrace, you can contour cut (if the image has a good edge ) then just make the cut path a shape (make path) then clip as above.
Hope this is clear
Post Fri Jun 09, 2006 3:04 pm
Peter, you are an absolute marvel! Job done!!!!! Thank you soooooo much. Big sloppy kiss for you.
I never even knew there was a clipping tool. Doh.
Thanks Marts and everyone else for your advice and support too.
:thanks2:
Lorraine, have you tried the cut out tool in Corel Photo Paint? very quick and good at picking out 'feathery bit'
alan
In total there are 39 users online ::
1 registered, 0 hidden and 38 guests
