printed fascia sign
Post Fri Jun 02, 2006 1:23 pm
printed fascia sign
Personally I don't like them but have been asked to do a fascia which needs do be done as a print. Not done a printed one before - is there anything to look out for?
Am a bit worried about the join to be honest, plus fading as south facing. Will get laminated.
Any input appreciated.
Ta.
Post Fri Jun 02, 2006 1:39 pm
how big is the fascia?
Post Fri Jun 02, 2006 1:54 pm
laminate definately, but avoid yellow if you can, it will be the first colour to fade :( May only be our environment here, but yellow is white in about a year here unlaminated.
Post Fri Jun 02, 2006 2:29 pm
George,
havent measured but from memory probably about 15ft wide (think that the 1070 x 170 pixel image supplied will have a bit of a struggle.......)
Shane - ta for that - it is mainly blue so hopefully wont fade so quick.
Post Fri Jun 02, 2006 2:33 pm
15' wide? as in 15' by say 3'?
Post Fri Jun 02, 2006 2:37 pm
George,
Probably 15 ft x 2.5ft.
Post Fri Jun 02, 2006 2:39 pm
Marts i cant see any problem with the join are you mounting it onto foam/dibond first?
Post Fri Jun 02, 2006 2:54 pm
George,
yes - will be onto dibond or foam - not sure yet. Guess am over paranoid of the joins not being spot on as will show with the continual print...
will bear your optimism and faith in mind...
thanks
Post Fri Jun 02, 2006 3:00 pm
i usually get both panels on a bench and mount the print as one the cut after then when fitting hope its a nice flat surface
Post Fri Jun 02, 2006 3:01 pm
Post Fri Jun 02, 2006 10:02 pm
Marts, you cant do a sail track banner? That would fix the join concern.
Post Sat Jun 03, 2006 1:05 am
Martin,
I wouldn't be worried about the join at all......ignore it....would prefer di-bond [or similar] rather than foam...The new Thomas Cooks, Thorntons etc are all digital onto aluminium and look great.
:D
In total there are 81 users online ::
2 registered, 0 hidden and 79 guests
