help please trying to find photoshop clipping program?
Post Fri Apr 21, 2006 10:18 am
A while ago l read an article in the "Signlink" magazine about a programme that acted as a photoshop filter for cutting out an object on a photo.
It looked extremely simple and easy to use, does anyone know the name of it?
Post Fri Apr 21, 2006 10:44 am
Billy,
Haven't seen the Signlink article - but have used Mask Pro from what used to be Extensis - they have been bought by Onone Software. I've used an earlier version which worked pretty well. I bought as part of their Photoshop Suite as can be expensive on its own. You can try a 30 day download. Details here if I can link properly: http://www.ononesoftware.com/detail.php?prodLine_id=4
Corel Knockout also removes backgound but I prefer the Mask Pro.
Photoshops own filter - extract - is pretty good too sometimes. You could extract, select and create path if you needed a cut line.
Post Fri Apr 21, 2006 10:46 am
I have a program called Fluid Mask that does this. It is on my Mac, but Vertus who make it have just released a Windows version.
It is one of the best add ins I have purchased. It saves so much time and is quite easy to use.
Tony
Post Fri Apr 21, 2006 10:30 pm
Thanks for that.
I think the one in SignLink was Fluid Mask.
Post Fri Apr 21, 2006 11:01 pm
hm.. its very easy in photoshop... just select the areas you want then Edit / copy, new file with transparent background then paste.
Post Sat Apr 22, 2006 4:27 am
Here's a tip , once you have a bitmap with a removed background , corel 13 has a new function called create boundry , what this does is put a vector line around any objects you select and thus the bitmap can be printed and cut VERY easily. IE if you have a butterfly and you remove background , corel will create a die line to cut it (which you can offset etc)
Works extremely well with very complex vector graphics and so forth. Corel trace also has a remove background function if you trace bitmaps.
Return to Adobe Software
In total there are 97 users online ::
2 registered, 0 hidden and 95 guests
