uksignboards.com uksignboards.com
“created by sign makers for sign makers”
Last 24 HoursLast 24 Hours Board RulesBoard Rules FAQFAQ  RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Search the boards :   Advanced Search
Espon 1290 printing onto vinyl?
Post new topic   Reply to topic   %s Forum Index -> General Printing Discussion
View previous topic :: View next topic
Author Message
Redproud
UKSB Newbie
PostPosted: Mon Mar 24, 2003 12:35 am    Post subject: Espon 1290 printing onto vinyl? Reply with quote
Is it possible to print onto a vinyl with an epson 1290 printer?
Any hints or tips with regards to the epson 1290 and what all its uses are please share.
I recently purchased one and have been very impressed with the quality of printing from it.
David
Back to top
becky
UKSB High Post Member
PostPosted: Mon Mar 24, 2003 12:48 am    Post subject: Reply with quote
we have an epsom1290, a very good printer. Not used it for vinyl.
Back to top
Martin
UKSG Member
UKSG Member
PostPosted: Mon Mar 24, 2003 1:01 am    Post subject: Reply with quote
David, its not really a simple yes or no question, there are lots of things you have to consider. The 1290 is an inkjet printer and there are inkjet receptive vinyls on the market so yes it will print onto vinyl.
But why do you want to print to vinyl? If its for outdoor use then the prints will not last as the inks the printer uses are dye based and are not UV stable nor are they waterproof. You could laminate them with either a UV laminating film or a liquid laminate, this would increase their UV stability and give them a degree of waterproofing but they will still fade realitivly quickly and you would probably not get much more than a few months at best.
If its for indoor use it would be cheaper to print onto a self adhesive paper and then laminate.
Back to top
Jodie
UKSB Newbie
PostPosted: Mon Mar 24, 2003 8:24 pm    Post subject: Reply with quote
If you print onto coated vinyl and then overlaminte with clear vinyl what happens is the coated vinyl acts as a sponge and will soak moister in from around the edges and will eventually get in between the two layers. Brian
Back to top
Display posts from previous:
Post new topic   Reply to topic    %s Forum Index -> General Printing Discussion All times are GMT + 1 Hour
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Roland DG (UK) Ltd |  SignUK |  Sign Making |  Sign Software |  Vinyl Cutters |  Vehicle Wrapping |  Sign Vinyl |  Sign Supplies Online |  Sign Fabrication |  Neon Signs |  Illuminated Signs |  Sign Writing |  Sign Carving |  Gold leaf Signs |  Sign Making Demonstrations |  Sign Videos |  Tips & Tricks |  Buy - Sell - Swap |  Sign Employment |  Sign Design Help |  Wide Format Digital Printing |  Sign Gallery |  CorelDRAW X3 |  UK Sign Boards |  Sign Industry News |  Screen Printing |  Brandsoftheworld.com |  FastSignsltd.com |
Copyright © 2002 - 2007 uksignboards.com Powered by phpBB © 2001, 2007 phpBB Group :: Spelling by SpellingCow.
