uksignboards.com uksignboards.com
“created by sign makers for sign makers”
Last 24 HoursLast 24 Hours Board RulesBoard Rules FAQFAQ  RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Search the boards :   Advanced Search
Versaworks - Adobe Illustrator CS4 cut path problem ??
Post new topic   Reply to topic   %s Forum Index -> General Sign Topics
View previous topic :: View next topic
Author Message
Shaun Cleary
UKSG Member
UKSG Member
PostPosted: Fri Feb 05, 2010 4:34 pm    Post subject: Versaworks - Adobe Illustrator CS4 cut path problem ?? Reply with quote
When I put a box (Cut path) around my artwork in adobe illustrator, sometimes versaworks only shows 3 sides with the moving line.
This means it only cuts 3 sides of a square.
Does anyone have any idea why this is ??
Back to top
Mathew Gibson
UKSB Regular
UKSB Regular
PostPosted: Fri Feb 05, 2010 4:39 pm    Post subject: Reply with quote
Make sure all of you artwork is inside the perimeters of the artboard
Back to top
Shaun Cleary
UKSG Member
UKSG Member
PostPosted: Fri Feb 05, 2010 4:53 pm    Post subject: Reply with quote
I have tried that,
(1) Brought artwork in from customers PDF
Box comes up This file contains text that was created in a previous version of illustrator.
This legacy text must be updated before you can edit it.
Choose update to update all of the legacy text now.
I then press update.
I have also tried sending this straight to Photoshop.
I tried flattening it and making it in to a Jpeg or new PDF and then opening it up in illustrator, both still don't work.
(2) Art board is big enough for artwork
(3) Put cut line around artwork 1 point stroke
(4) Open in Versaworks only 3 sides have cut path
I have tried a different jpeg this way and EPS file and both are fine.
Back to top
OwenTaylor
Silver Member
Silver Member
PostPosted: Fri Feb 05, 2010 5:03 pm    Post subject: Reply with quote
That's happened a few times to me, once I was cutting a hundred decals and it decided to cut 3 sides on a random selection of the stickers. Here's how I fixed it:
edit - adjust the queue a/b settings before you load up the job. I just tried and it was greyed out when the job was already uploaded.
Go to queue a or b job settings (whichever you are using). Under the 'file format' tab the top box is for the EPS margin settings. Add a margin of 0.5mm and your cutlines should appear. I think the margin has to be above 0.35mm or it won't work so I just use 0.5mm.
Hope that helps!
Back to top
Shaun Cleary
UKSG Member
UKSG Member
PostPosted: Sat Feb 06, 2010 11:11 am    Post subject: Reply with quote
Tried all of that with no luck all other files work but this one.
Back to top
OwenTaylor
Silver Member
Silver Member
PostPosted: Sat Feb 06, 2010 1:28 pm    Post subject: Reply with quote
Can you attach the file - I'll give it a try in Versaworks
Back to top
Shaun Cleary
UKSG Member
UKSG Member
PostPosted: Sat Feb 06, 2010 9:11 pm    Post subject: Reply with quote
Do you know how to attach a file on to this post.
Back to top
Display posts from previous:
Post new topic   Reply to topic    %s Forum Index -> General Sign Topics All times are GMT + 1 Hour
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Roland DG (UK) Ltd |  SignUK |  Sign Making |  Sign Software |  Vinyl Cutters |  Vehicle Wrapping |  Sign Vinyl |  Sign Supplies Online |  Sign Fabrication |  Neon Signs |  Illuminated Signs |  Sign Writing |  Sign Carving |  Gold leaf Signs |  Sign Making Demonstrations |  Sign Videos |  Tips & Tricks |  Buy - Sell - Swap |  Sign Employment |  Sign Design Help |  Wide Format Digital Printing |  Sign Gallery |  CorelDRAW X3 |  UK Sign Boards |  Sign Industry News |  Screen Printing |  Brandsoftheworld.com |  FastSignsltd.com |
Copyright © 2002 - 2007 uksignboards.com Powered by phpBB © 2001, 2007 phpBB Group :: Spelling by SpellingCow.
