uksignboards.com uksignboards.com
“created by sign makers for sign makers”
Last 24 HoursLast 24 Hours Board RulesBoard Rules FAQFAQ  RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Search the boards :   Advanced Search
Sign extra
what is the max ram you can use with xp pro please?
Goto page Previous  1, 2
Post new topic   Reply to topic   %s Forum Index -> Computers, Scanners etc
View previous topic :: View next topic
Author Message
David Glen
UKSB Regular
UKSB Regular
PostPosted: Fri Nov 02, 2007 10:09 am    Post subject: Reply with quote
Cheers, I'm going to look into it.
Back to top
Jason Xuereb
Gold Plus Member
Gold Plus Member
PostPosted: Fri Nov 02, 2007 10:13 am    Post subject: Reply with quote
Is the 64bit Xp version backward compatible with 32 bit applications?
Does anyone know if photoshop is going to have a 64bit release soon?
Back to top
tived
UKSB Newbie
PostPosted: Fri Nov 09, 2007 2:53 am    Post subject: Reply with quote
Yes, x64 is backwards compatible - unfortunately! So much for progress!
I doubt that you will see a x64 bit version of Adobe product anytime soon. Apparently there isn't that many features in Photoshop that can take advantage of the wider data path.
You can access more memory in windows xp x64 and Vista x64, and photoshop can use more memory in x64 compared to x32.
I have two machines one (Dual Opteron 285, Dual Core) running xp x64 with 8gb and an Intel Quadcore 2.66 with 4gb running vista Ultimate x64, non of them would run FlexiSign 8.1 :-(, but I have CS3 Design Premium and that is running very nicely.
Hope this hepls
Henrik
Back to top
tived
UKSB Newbie
PostPosted: Fri Nov 09, 2007 2:55 am    Post subject: Reply with quote
It is my opinion that currently XP x64 is more stable atm and have better driver support compared to Vista x64, but this will all change within the next year.
Henrik
Back to top
Jason Xuereb
Gold Plus Member
Gold Plus Member
PostPosted: Fri Nov 09, 2007 3:15 am    Post subject: Reply with quote
Cheers mate.
Do you use photoshop for larger files? Whats your hard drive setup?
I've read so much on the net lately I'm a little confused to what computer to build next.
Alot of things I've read have said the bottle neck for photoshop etc is the hdd because you can't have enough memory on xp 32bit. But if you can run 64bit and have 8GB of ram then most of my work would remind in memory instead of being written to the hard disk.
I'm also told that having a dedicated hard disk for photoshop scratch disk improves performance also.
Back to top
steve day
UKSB Newbie
PostPosted: Wed Dec 19, 2007 12:39 pm    Post subject: Reply with quote
just to add to this, i just installed 4 gig of ram onto an XP 32 bit machine and it recognises 4 gig in bios but only shows 3.25 gig in windows it self. It does help with massive graphics, almost the same as using small graphics
Back to top
tived
UKSB Newbie
PostPosted: Mon Jan 14, 2008 5:10 am    Post subject: xp x32 will not install with more then 4gb installed Reply with quote
as the above, I have had no luck installing XP x32 on one of my workstations, with 8gb of ram. Though XP x64 and Vista x64 loves it
Henrik
PS: and to have more then 2Gb you need to use the /3Gb switch to access the address space above 2gb
PPS: just to add to what Jason so rightly said, a dedicated hard disk for scratch disk is an improvement, but a raid 0 for scratch disk is twice as good :-) which is why I have 8 disks in my workstation
Back to top
Jason Xuereb
Gold Plus Member
Gold Plus Member
PostPosted: Mon Jan 14, 2008 7:30 am    Post subject: Reply with quote
tived,
What are you designing
Back to top
tived
UKSB Newbie
PostPosted: Tue Jan 15, 2008 12:17 am    Post subject: Reply with quote
Hi Jason,
I do mainly photographic retouching and color management for other photographers, and only recently joined one of my friends in his sign-writing business.
I did prepress back in 2000, but haven't done much since, so I am a bit rustic in that department.
so nothing that exciting.
Henrik
Back to top
Display posts from previous:
Post new topic   Reply to topic    %s Forum Index -> Computers, Scanners etc All times are GMT + 1 Hour
Page 2 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Roland DG (UK) Ltd |  SignUK |  Sign Making |  Sign Software |  Vinyl Cutters |  Vehicle Wrapping |  Sign Vinyl |  Sign Supplies Online |  Sign Fabrication |  Neon Signs |  Illuminated Signs |  Sign Writing |  Sign Carving |  Gold leaf Signs |  Sign Making Demonstrations |  Sign Videos |  Tips & Tricks |  Buy - Sell - Swap |  Sign Employment |  Sign Design Help |  Wide Format Digital Printing |  Sign Gallery |  CorelDRAW X3 |  UK Sign Boards |  Sign Industry News |  Screen Printing |  Brandsoftheworld.com |  FastSignsltd.com |
Copyright © 2002 - 2007 uksignboards.com Powered by phpBB © 2001, 2007 phpBB Group :: Spelling by SpellingCow.
